-   -   High performance plenum system for aftermarket EFI ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1086051-high-performance-plenum-system-aftermarket-efi.html)
Mark Henry 02-14-2021 11:40 AM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/895593-efi-systems.html
I've seen lots of ITB system builds as above and I'm no newbie, for T4 and I've built my own motorcycle ITB's and have used Jenvey's and CB on other projects.
What I don't like about ITB's and EFI is running in alphaN or a TPS only system. It was great when I was younger but now that I'm older I want it to run more like a factory performance street car...with power of course.
Right now I have a good running hot street 3.0 twin plug with Weber 40IDA and MSD with a Patrick/Jarvis dizzy, runs great no complaints other than it smells like a carb car.
I just acquired a complete EFI system with twin plug ignition.
I also have a 2nd 914/6 project with a 2.7 engine that I'm planning to build, it will need the other intake and ignition system, so it's either carbs or this system but one of them is getting the FI.
First I know I could just buy a 3.2 intake and be done with it, but that's going to be like $1500 Canadian. Or I could mod a Boxster intake, but I'm a cheap and I like to fabricate things, so I was also wondering if one can make a better tuned plenum system?
BTW my cars are both 914's, so for the most part you can't see much other than the tops of the rain hats.
Here below you see a system for a Subaru being built (aircraft conversion), but I think I would build it more like the later Porsche intakes that have the 2 separate plenum halves. The 996/997 runners are ballpark 14" I have both a 996 3.4 and a 997.1 3.8 intake here, I'll pull them down and properly measure them.
http://www.sdsefi.com/eg3322.jpg
http://www.sdsefi.com/eg3321.jpg
http://www.sdsefi.com/eg33man3.jpg
These are mild steel that are then powder coated, I imagine I could do them in aluminium.
Question is would you think the power loss will be so bad that it's a bad idea? Change my mind.
How long would you make the runners?
How straight would you keep the runners? Or would you curve them more like 996?
Mild steel powder coated or aluminum? Why?
Has any one already done this? Linky please?
If it such a bad idea I can always do a triumph TB build, sort of like what I did here: 914World.com - The largest online 914 community!
I'm not in a rush, I might not even start this till next winter, I just want to see what ideas come from this group.
Yea or Neh on the plenum?
Walt Fricke 02-14-2021 10:35 PM
Don't turbo plenums of this sort taper, so the farthest cylinders get as much air as the nearest? Or isn't that a consideration for NA?
Mark Henry 02-15-2021 05:38 AM
That's a turbo thing, but it's not much of design issue more because you can with a turbo, my buddy did it only to avoid interference with other parts under the hood.
dannobee 02-15-2021 06:25 AM
Optimal intake cross section area and length on normally aspirated engines are mathematically computed and have been known for several decades. Nothing new there. Here's just one of many online calculators.
Intake Runner and Peak Torque Calculator
Generally speaking, you want the plenum volume to be as low as practically possible (for a flat six anyway). If you find that increasing the plenum increases horsepower, then the throttle body is too small. If it's too big throttle response will suffer. Since we're connecting to halves of a flat six, consider each bank of three to have its own plenum, with a big balance tube between.
As the RPM capability of an engine increases, the optimal runner length decreases.
As the engine displacement increases, the intake runner cross section needs to increase.
As far as injector placement, the higher up in the intake runner the injector is, the more power the engine will make. There is no disputing this fact. The only reason that production cars have injectors mounted close to the intake valve is for cold start emissions reduction and idle characteristics, not for performance. Use that info to meet your objectives.
Porsche does a very good job with its intake manifolds and I've found that when checking cylinder head flow rates on a flow bench, the flow will often INCREASE at mid-lift with the intake runner attached. I'd use the Porsche intakes as a guide if I were to build an intake; they've already "done the math."
The latest in intake material tech is plastic. It's very likely that you could 3D print one if you have the capability. Aluminum would be a second choice because of light weight and thermal conductivity.
With turbos, all bets are off. You could pretty much connect everything with a big box and short runners and given enough boost, it'll still make good power. And if it isn't enough, you simply add more boost. Yes, intakes can be optimized with turbo cars, but packaging concerns tend to be the driving factor.
Mark Henry 02-15-2021 08:25 AM
Thanks I'll play with the calculator later.
The MY/96 head has a wider intake manifold pattern so other than a reference and maybe the odd part I don't think a boxster plenum will work for this purpose.
This is a NA plenum discussion only please.
Thanks Mark
stownsen914 02-15-2021 08:28 AM
I've noticed that some builders of very high output NA 911 motors are putting GT3 plenums on top of their ITBs. The factory has put plenums even on non-restrictor motors. I don't know enough to comment intelligently on specifics, but there must be something to it.
Jim2 02-15-2021 09:20 AM
Ahhhh, so that's where that system went!
Mark Henry 02-15-2021 10:23 AM
Yep... Chris made me a deal I couldn't refuse ;)
winders 02-15-2021 10:56 AM
Porsche put a resonance intake system on top of ITBs on the 993 RSR normally aspirated race engines.
Gunther Werks uses the 996 GT3 intake with ITBs on their specials 993 cars and Singer uses that same intake on most if not all of their cars.
The idea being to gain midrange torque using the resonance to fill the cylinders faster/more efficiently in certain RPM ranges which improves drivability. I am not sure what happens at the top end.
Mark Henry 02-15-2021 11:14 AM
I'll look at the GT3 but;
-one I bet it's too expensive.
-two I think it would be too tall for my 914 engine bay.
I don't want to lose a lot but I'm Ok with a slight loss at WOT.
My bet is I won't lose much because the 40IDA's I have now are a bit on the small side for my 3.0 big port, twin plug, 120/104 cammed engine, it should have 46mm webers.
The 40IDA's I have are better suited to the 2.7 I'm going to build.
Mark Henry 02-16-2021 05:53 AM
So looking at the GT3 manifold I'm going to build something like it.
I'll build it in mild steel similar construction to the pics I posted above, maybe try a couple designs. If I get one I like I may copy it in CF or aluminum, but for now I'm not worried about using powder coated steel as a material.
targa72e 02-16-2021 12:48 PM
Hi Mark,
intake style is somewhat dictated by the camshaft choice. Individual throttles help with reversion for cams that have a lot of overlap. Common plenum with single throttle limits cam choice to those that typically have less overlap. Plenum over ITB is a way to run more aggressive cams and use resonance tuning to help broaden and enhance the power curve. GT3 intake is often referenced for larger engines and 964 plastic runners for smaller. When used on top of ITB the front crossover where the throttle would normally be becomes a air filter inlet. The rear cross over tube has the resonance flap that is opened or closed depending on RPM. I do not know enough about intake design to know if there is a reason Porsche did not use a single center chamber or if it was a packaging decision.
john
Mark Henry 02-16-2021 01:19 PM
Originally Posted by targa72e (Post 11227250)
Hi Mark,
john
I'm well versed in the 996 and 997.1 plenums, I have one of each here on the wall.
This EFI system was spec as a turbo system (930) IIRC this system has extra relays that can be programmed to turn on/off certain items like fans, etc. and likely this flap. I know this resonance flap runs off of vacuum and has a "can" under the plenum but it also has a electric valve controlling something to do with this as well.
I think I'll dry fit the 2.7 for a jig and work from there.
winders 02-16-2021 01:33 PM
With the smaller displacement engines like the 2.7L, the 964 and 1995 993 plastic intake setup is going to be better than the 996 or 997 intakes. They are not plenums, by the way.
Mark Henry 02-16-2021 05:19 PM
It's going on a 3.0 big port twin plug, RSR style Mahle pistons, web 120/104 cams that's presently running perfectly on 40 IDA webers and MSD with a PMS/Jarvis TP dizzy and wires.
The EFI system is a SDS EM5-F with twin plug coil packs, that I'm sending in to be upgraded to 2021 software spec and add the port for full data-logging.
The 2.7 engine I have will only be used as a jig, but the plan is to one day build it for a 2nd car I own with the Webers and MSD.
winders 02-16-2021 05:39 PM
Jeff Gamroth has used the 3.6 plastic intake with great success on the 3.0L engines. I would think the 996 GT3 intake has too much volume to work as well.
914efi 02-20-2021 08:30 AM
I built this for my 914-6 almost 20 years ago, hard to believe. Not sexy, but it worked well and is designed to fit a 914. I found a place near me in RI [Tubodyne, I think] that bent the aluminum tubes. Hardest part was making the injector blocks, early version had the injectors higher as seen in the photo.
Today, the machining would be much easier. I think the high injector position was fine after all. Happy to share CAD files. If nothin else will tell you what will fit. Still have the jig for welding the tubes.
shownhttp://forums.pelicanparts.com/uploa...1613838228.jpg
Mark Henry 02-21-2021 02:38 PM
Cool thanks,
One of my 914world good buddy's is going to send me a set of 964 aluminum intake halves.
They were in a topside fire so just the two halves, I'll have to source or make the center bits.
I also realize if I go this route I also have to make the head/injector part, rails, etc.
winders 02-21-2021 02:49 PM
Are you going to use a flapper setup so you can optimize mid RPM torque? Does you ECU have the ability to control the vacuum valve?
Mark Henry 02-21-2021 05:59 PM
Not sure, I know it's vacuum activated but is it just a solenoid opening an on/off valve?
I do have a few relays for NOS and meth injection I can re-purpose.
winders 02-21-2021 06:04 PM
Yeah, it is just a solenoid controlled vacuum valve. Most ECUs have the capability to control such a solenoid based on an RPM window. You could even control it with an aftermarket RPM switch if your ECU could not...but it seems like you are good to go.
Mark Henry 02-22-2021 07:40 AM
Yes these relays can be RPM programmed to do different things, AC, fans, switches, etc.
Jim2 02-22-2021 08:26 AM
Mark, the flapper is a butterfly actuated by a vacuum pot, activated by a solenoid valve. Vacuum supplied by a reservoir. A solenoid connected direct to the butterfly arm should work fine.
winders 02-22-2021 11:07 AM
Do you have examples of the resonance butterfly being controlled directly by some solenoid? I would like to see that as it would save people from installing a bunch of vacuum lines, valves, reservoirs, etc.
Jim2 02-22-2021 09:20 PM
Mark, here are some photos where the black plastic intake is a 1995 993 and the alum intake is about an 89 or 90 964. In the closer pictures of the 964 you can see the flap butterfly. Unfortunately I tossed this 964 part when I built a simplified replacement which is essentially a couple tubes, throttlebody, and your good to go. If you integrate a "flap" it was nothing other than a butterfly. Though this 964 part was magnesium it weighed quite a bit. Anyhow it's probably not difficult to find a used one.
Here is a description of the flap operation as written by Steve Wong:
Post from Steve Wong 5-25-2007
Checking Resonance Flap for Operation:
When the ignition is switched on, the resonance flap is closed by vacuum action. When the ignition is switched off, the resonance flap is opened (rest position). The opening and closing noise is audible in the engine compartment.
4. Resonance Flap
The DME control unit activates a vacuum-controlled diaphram valve which either opens or closes the resonance flap.
The resonance flap is closed between 3,000 prm and 5,000 rpm and at throttle opening angle of > 60 degrees.
Due to the ignition sequence, the intake system is alternatively supplied by both tanks. Due to the firing order, air is drawn in an alternating manner from both intake system tanks. If resonances occur, the intake frequency of one row of cylinders matches the natural frequency of the pressure vibrations in the respective tank. The natural frequency is determined by the geometry of the intake pipes, the resonance pipe and the tanks. A crucial factor, however, is the total length of the pipe from the actual intake cylinder to the next cylinder being supplied, the distribution in intake and the resonance pipe lengths as well as the depth of the tank in the direction of flow. In the no-current state, the resonance flap is open. As soon as the ignition is switched on, however, it is triggered and closed. If the DME control unit detects that the engine is being started, the resonance flap is opened again.
Pin 1 from the DME unit is used to control the resonance valve.
http://forums.pelicanparts.com/uploa...1614057205.jpg
winders 02-22-2021 10:47 PM
Also note that the flapper in the 964 plastic intake setup is open when the solenoid is not activated (no vacuum) while the 1995 993 flapper is closed when the solenoid is not activated (no vacuum).
Well, it could be the other way around but I am 99% sure I have that right.
Mark Henry 02-23-2021 08:40 AM
Thanks for the pics Jim, the intake I'm being given the center parts/TB were destroyed in the top end fire, so it's good to see what you did.
targa72e 02-23-2021 12:54 PM
This is taken form another forum but shows a dyno from working and non working flap on 964 (plastic intakes). As you can see it makes a pretty big difference on the top end power.
http://forums.pelicanparts.com/uploa...1614113649.jpg
john
jpnovak 02-23-2021 03:00 PM
FYI a small 12V servo motor with actuating arm on a custom bracket mount can drive the resonance valve on the 964/993 intakes rather than the vacuum pod. This can easily be triggered by most EFI systems using an I/O pin.
winders 02-23-2021 04:17 PM
I suspect the Porsche Factory chose to use the vacuum system because it was less prone to failure than a 12v servo motor strong enough to move the flapper and able to deal with being activated for long periods of time. A solenoid is much less likely to fail.
I'd like to see a servo motor setup that works and is reliable. Has anyone seen such a setup? All of the systems I have seen with a resonance flapper use a vacuum system. As I said, it would sure make things simpler...
JoeMag 02-25-2021 05:24 AM
Scott - you are correct on the 993 plastic intake, resonance flap is spring loaded closed.
All others - have a 993 plastic intake with resonance flap and throttle body tube with throttle if anyone is interested.
I saw similar results on my motor as the dyno with res flap closed beyond 5.5k.
Mark Henry 02-25-2021 07:14 AM
So basically it looks like the flap opens at 5500rpm and stays open to my redline. That's easy enough to do.
First I have to get the two fire damaged intake halves I'm getting, to see if they're useable, before I can start fabricating. They're in Texas so I do have to wait a few weeks for the fellow to recover from the cold snap.
In the meantime I just sent my ECU in for an update cable install, this will allow me to update the software via download to current 2021 spec (system is a 2012), better datalogging and a few other feature details.
Totally worth it as it's only costing $125, which was about the cost of chipping the previous systems once.
Mark Henry 02-25-2021 12:56 PM
Dang, my buddy can't find the intake so I'm back to square one.
I shipped my ECU off to get the data logger daughter board and cable installed. More Importantly this allows me to download and update the software when new versions come out. Only cost $125 plus the shipping for this upgrade.
winders 02-25-2021 02:15 PM
Check with JoeMag to see how much his 993 intake setup would cost you.
Mark Henry 02-25-2021 03:51 PM
Thanks Scott I didn't even see that.
JoeMag I'll send you a PM.
winders 02-25-2021 09:09 PM
Originally Posted by Mark Henry (Post 11239826)
Thanks Scott...
My pleasure!
ross79SC 02-26-2021 10:08 AM
I stumbled across 'Adapt Motorsport' from Australia... they have 964 manifold stuff like billet 2 bolt adapters, developing a DBW throttle body etc. Aussie $ is pretty much on par with the loonie to boot.
adaptmotorsport.com
Ross
Mark Henry 02-26-2021 11:46 AM
adaptmotorsport.com
Ross
Thanks, I'm capable of this in-house.
Mark Henry 02-28-2021 04:08 AM
I just made a deal on two 964 aluminum intake halves, so I should have them before this Friday.
A member on 914world suggested a reversion flapper out of a Nissan that looks promising.
http://www.914world.com/bbs2/uploads...14480547.1.jpg
Evan Fullerton 02-28-2021 06:31 PM
J Series Honda V6 have an electronic cable actuated resonance flap.
