LinkBack | Thread Tools | Rate Thread |
cylinder base shim sealant - question that my gut already knows the answer to
I'm in the process of getting my '71 2.2T engine back together to go into my 914.
When I installed my pistons and cylinders and checked/adjusted deck height etc. I applied Threebond 1215 to the mating surfaces, i.e the case, the shims, and the cylinder bases. a week or two later I'm getting ready to progress and I believe I need to pull them all again and reapply only just before I'm ready to install and torque down the heads. That's at least the route I'm planning on unless one of you with experience on the issue says otherwise.
Instagram = glen.cordle for my Porsche artwork and 3D models. |
I never used any sealant on the cylinder base gaskets, and never had any leak. not even sweating. I suggest sealant may not be required if seal surface looks good
80SC (ex California) |
+1 for Trond. Never glued base gask. A lot of folks do, no confidence in their work.
Curil T is what I would use as recommended by Wayne and Henry Schmidt.
Here is some good reading on this from sealant for cyl. gaskets. Quote:
Never used anything.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Used Curil-T with success so far.
'85 911 Carrera 3.4 Turbo |
Threebond 1215 was also suggested for this location in the sealants thread.
Try not, Do or Do not
Any non-hardening, oil resistant sealant will work. I use CurilT because I read somewhere that it was certified for nuclear reactors.....that's god enough for me.
For those who resist using sealants as a safe-guard: what's the harm? If the cylinders leak, you have 25 hours worth of work ahead of you.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
agree. stupid not to really. No downside at all to use some. It is a big job to go back
It's a 914 ...
Not sure if anyone answered the OP's question about whether the sealant needs to be reapplied. I'd say that since the sealant cures (semi-hardens) and the heads are not installed and torqued, yes it needs to be cleaned and sealant reapplied.
Yeah, thank you for responding. I am planning to do that but I chose to order new base shims because these things bend so easily. Worth it to not have to try and clean the old-new ones up.
