Been here a while
ARP head studs. Broken
I’ve got a 3.6 in my 83 SC.
I’ve owned the car for 6 years, I don’t drive it more than 2-3000 miles a year, had a valve adjustment right before I bought it...and mechanic gave it a thumbs up. Owner prior to that did the 3.6 conversion. It’s been 10 years but at most 20,000 miles....both prior owners are Pelican guys. The guy who did the swap sourced great parts, didn’t skimp in anything and he had the motor rebuilt by “one of the best guys around denver”...used ARP head bolts On doing my valve adjustments, I found 2 nuts loose, and those two had broken head bolts. I’m curious if this is a known thing with ARP (doubt it)...if it’s possible the “best” engine builder did something wrong.....or something else.... Anyone have some insight? I figure I can call ARP tech support just to see what they say, not expecting any freebies or warranty after all these years, just curious.
looking for 1972 911t motor XR584, S/N 6121622 |
Do you have a pic of the ARP stud?
The 964 comes factory with 24 dilivar studs.
Just a thought.... Bruce |
Been here a while
Is that head stud magnetic? If not it's probably the factory Dilavar. Easy to check.
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 03-07-2021 at 06:00 PM.. |
Ok, "one of the best guys around" padded the bill... OR the seller was not forthright with you. That is not an ARP head stud.
As much as I like ARP head studs, and have used them extensively, we are going to give Henry's Supertech studs a go on our next builds that require more than factory steel studs. As you need new ones, both of the above will work for you, do your research and make your choice. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I have a set of factory Porsche steel head studs, I bought them new, cleaned them, taped off the threads, painted with VHT satin black brake caliper paint, then baked them at 200 deg for an hour. It's possible someone painted a set of ARP studs, but not likely.
Then I decided to just get the Super Tech head studs and remove one concern from my build. Last edited by reclino; 03-07-2021 at 05:11 PM.. |
Ingenieur
ARP studs don’t come painted. The Dilavar studs would have had the rolled thread surface. Maybe ARP studs that were painted? All this “retorquing” bothers me. One wonders what torque they were using.
As stated above, it's NOT an ARP stud, nor is the nut correct ARP hardware. That's why I asked for a pic.
Something fishy went on. As Henry said, it's a Porsche dilivar stud, which are known to break. |
![]() ![]() Its a factory original stud. Someone got lead down the garden path... so to speak...
Racer
Maybe they used ARP rod bolts on the build.......
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Ingenieur
The 964 used these, according to the PET:
Always possible that someone substituted the older style Dilavar. Easy to check with a magnet. Quote:
Racer
Porsche says to use these now. But, when the 964 came out, there was no 993 part number head studs....much less the 993 Twin Turbo head studs.
Probably only US 964 engines... ROW seams to have 24 steel head studs, but I've only touched 3-4 3.6 engines.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Been here a while
Magnet doesn’t stick.
@speedy squirrel....I don’t understand the retorquing comment ...I don’t recall any other discussion, and on this motor, I didn’t ever torque the nuts, and I don’t have an invoice for anyone previously needing to torque the nuts. Thanks for all the insight folks. I’ll look thru the build documents I have and see what I can find. Also, the original builder says he’ll talk to the engine builder Friday and report back. Seems like there’s more to this story.
All 964 engines came with a full array of coated, smooth shank, Dilivar studs. It wasn't until the factory noted an unusually high failure rate of these Dilivar studs that they went back to steel studs in early 993 engines. This was very short lived. Warranty issues (weeping heads) caused them to reevaluate their choice of steel and reinvented the Dilivar. This time with an all thread monstrosity that offered a slightly more aggressive clamping force and marginally reduced failure rate.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Puny Bird
ARP head studs have the bullet end to aid the nut being threaded on, so definently not ARP
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Racer
Now you are just being ridiculous. The 993 Twin Turbo fully threaded Dilivar head studs work extremely well. It seems all you want to here is knock a part that threatens sales of your head studs.
Been here a while
Thanks Henry and everyone, good to know these aren't ARP.
So the consensus is these are factory 964 (circa 1989) head studs...breakage is normal, and I'm sure in time more will break. So I've got a project for next winter I suppose. Thanks everyone.
