The 9 Store
3.2 clutch ID
How do I identify a clutch and pressure plate for a 3.2 engine with a 915 trans?
All used parts sold as is. |
The clutch TOB will be for the finger engagement .
The 915 is a smaller clutch disc than the g50 The clutch pack is the same from 72 to 86 The G50 TOB fingers install horizontally and is the same size as the turbo clutch Make sure you have 915 splines on the clutch, not 911 or 925 splines Bruce |
The 9 Store
