Idler Chainwheels
Hi,
Can anyone give me the history of the idler chain wheels, I have 2 types (note they are both bushed), The top one came from a 71E and the lower one (which seems closer to the contemporary) from a 914-6, though both engines have been rebuilt at some time so who knows.
Also how do you check these for wear other than a visual inspection?
Cheers Neven
Old 04-05-2021, 04:58 PM
BURN-BROS's Avatar
Interesting, I have never seen an early style have a bushing. I believe the lower sprocket was introduced during the mid year cars and definitely with the SC. I have never seen any problems with the non bushed sprocket.... only the idler arms. As far as wear, I have not seen one with an issue. They are just along for the ride.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 04-05-2021, 06:00 PM
Thanks Aaron,
You confirmed what I suspected that the later style has been replaced in the earler engine, and yes there is little wear on either. Would you recommend bushing the idler arms or upgrading to the later (wider bearing) ones? (Which seem overly expensive)
Cheers Neven
Old 04-05-2021, 06:12 PM
BURN-BROS's Avatar
The best improvement to the timing components was the wide idler. It has 2 bushings and a generous area for oil to accumulate between the bushings. This is the real “update” to the timing design changes
Supertec mods the non bushed to a wide version for a reasonable price if you are inclined to make the change.
Old 04-05-2021, 08:17 PM
Thanks again Aaron, yes very interested in the supertec version, Does anyone have a picture and a price?
Old 04-05-2021, 11:42 PM
I just picked up a set from Henry. I don't recall the price but it was very reasonable, definitely cheaper than the factory wide arms. Here's a picture of them next to my old ones. They look great even if you won't see them when the engine is built.
Sent from my SM-G991U using Tapatalk
Old 04-05-2021, 11:53 PM
David Gouk Race Engines
Bore gauge set at the pin size and check the clearance.
Old 04-06-2021, 03:01 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Pin fit is not a critical measurement. The important numbers are rotational friction and torsional support.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-06-2021, 03:55 AM
im talking on the idler wheel bushing
Old 04-06-2021, 04:01 AM
