Tips for replacing ex manifold studs
Anyone have any good tips for removing the exhaust manifold studs from the heads? I was going to just grip them with vise grips and twist them out. Should I heat the head with a torch first?
Thanks. Roger |
why, is the first question. best to let sleeping dogs lie, unless there's a good reason. they don't come out easy, and generally need to be drilled. that requires a jig, so the drill is dead center and doesn't go off into the aluminum head and create more problems.
Author of "101 Projects"
As usually, I agree with JW...
Don't pull them out unless they are super-rusted. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
