-   -   3.0 to 3.2ss (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1091251-3-0-3-2ss.html)
phunt 04-16-2021 05:27 PM
3.0 to 3.2ss
i have a 3.0 '82or '83 any way i am in process of going to 97mm nikkies 10.5-1 i am going to twin plug the heads with jb distributer and run the dc30 cams with carbs for induction has anyone run something like this or similar if so did you run 40 ida or 46 i think 46 is too big and 40 may be too small street engine stoplight to stoplight no track thanks
snbush67 06-09-2021 04:05 PM
When I did similar everyone recommended 46’s, that’s what I went with. No regrets.
Jeff Alton 06-09-2021 09:01 PM
With that displacement I would run 46. WHat made you choose the DC30? Also, why not 98mm? Your 97mm choice nets you a little less displacement...
Cheers
BURN-BROS 06-10-2021 04:30 PM
I don’t think I’d ever choose anything less than a Mod S for the 3.2ss. Engine is big enough to give you midrange torque with that cam, yet give you a redline like a 73S….
