ARP rod bolts ground when balancing
My new rod bolts where ground when they balanced the engine. ??
Lyndonhttp://forums.pelicanparts.com/uploa...1618996722.jpg |
I hope you didn't plan on using a stretch gauge. If it were me, I would be chosing another machine shop in the future.
I had to read them the riot act. They have now decided to replace them and grind of the appropriate amount that was taken from the bolts.
Lyndon |
Well that's a good response.
What about removing material from the rod cap rib? Is that correct practice?
Not when the bolts are in the way .
I agree with '78 SC.
Additional information Rod balancing - where to remove material
| All times are GMT -8. The time now is 12:17 AM. |
