ARP rod bolts ground when balancing
My new rod bolts where ground when they balanced the engine. ??
Lyndon
Old 04-21-2021, 02:18 AM
I hope you didn't plan on using a stretch gauge. If it were me, I would be chosing another machine shop in the future.
Old 04-21-2021, 06:09 PM
I had to read them the riot act. They have now decided to replace them and grind of the appropriate amount that was taken from the bolts.
Lyndon
Old 04-21-2021, 06:17 PM
Well that's a good response.
Old 04-21-2021, 06:36 PM
I am my 911's PO
'78 SC's Avatar
What about removing material from the rod cap rib? Is that correct practice?
Old 04-22-2021, 07:27 AM
Not when the bolts are in the way .
Old 04-22-2021, 03:53 PM
I am my 911's PO
'78 SC's Avatar
My point was that the rib on the rod cap is there for strength and should not be ground away for balancing. The shop needs to replace the rods, too.
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 04-23-2021, 04:55 AM
I agree with '78 SC.
Originally Posted by Henry Schmidt View Post
Removing material from the rod cap ridge on a 911 rod is never a good idea. The "ridge" is structural and designed to provide rigidity. Some people grind this boss (ridge) to balance the rod but even this small amount compromises the rigidity and may allow excessive cap flex at higher rpm.
Taken from Lighter standard rods - how much is too much?, Post #15.
Old 04-23-2021, 08:39 AM
Additional information Rod balancing - where to remove material
You should remove material from the square edges near the bolts.
I would also remove material from the small end of the rod not the wrist pin.
Removing material from the pin works well for balancing the pistons but if in the future you replace the piston, you will have to remember that the new wrist pin must be balance to the rod. If the next mechanic doesn't know you could drive him crazy.
Old 04-23-2021, 08:49 AM
