-   -   Piston squirters and Nicksil question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1092203-piston-squirters-nicksil-question.html)
Lyndon302 04-29-2021 01:00 AM
In a 2.0L 67 S. Can I run a Nicksil barrel as I'm going to an 81mm JE.
I do not have piston squirters nor will I as I'm in Australia and no-one is competent in doing it.
Lyndon
faapgar 04-29-2021 06:00 AM
cylinders
Use an 84mm biral cylinder from a 2.2-2.4.Bore to 85mm and make a true 2.3 Litre.Nicasil of course.Fred
Lyndon302 04-29-2021 07:57 AM
I have 2.0 S heads . I believe they wont fit.
Lyndon
gled49 04-29-2021 09:52 AM
You should be ok without squirters. 2.2S’s didn’t get squirters until 71.
Black 993 04-29-2021 08:38 PM
I'm far from an expert but I thought the reason for the factory's switch to squirters was the move to all-alum p/c's?
Mark Henry 04-30-2021 07:01 AM
I have a type 4 914 2.0 overbored to 2.6 with nickies/JE and 180HP, all I have is groves cut into the rods for "poor mans squirters". I do have an oversized oil pump to give me a boost in flow.
gled49 04-30-2021 08:29 AM
911R had ALU cylinders with chromal coating, no squirters. Normal production all ALU cylinders didn’t arrive till 73 2.7RS.
Henry Schmidt 04-30-2021 08:58 AM
The reason for squirters was to control piston temperatures.
Neven911 05-09-2021 04:31 PM
Was this to allow for smaller piston to cylinder clearance? and reduce noise from piston slap?
otto_kretschmer 05-10-2021 04:41 PM
as displacement increases, the pistons get bigger and with more power there will be more heat to get out of the engine
the center of the piston crown will be the hottest part of the piston because its the farthest from the rings
heat is absorbed from the combustion gases to the piston crown, the heat will flow to the rings and into the cylinder wall
heat will also flow from the piston to the gudgeon pin to the rod then down to the crank
the oil squirters spray oil onto the bottom side of the piston crown to keep the piston from getting too hot
Tyson Schmidt 05-22-2021 11:17 PM
Piston squirters allowed them to run thinner rings, improving sealing and reducing friction. The ring doesn’t have to conduct as much heat away from the piston crown to the cylinder so they were able to reduce the ring width of the 2nd ring to 1.5mm from 2mm.
Neven911 05-29-2021 08:06 PM
That makes sense, Though the introduction of piston squirters did coincide with the first use of nikasil they weren't exclusive to it, So what you are saying is you don't need squirters is you have the thicker rings?
