Piston squirters and Nicksil question
In a 2.0L 67 S. Can I run a Nicksil barrel as I'm going to an 81mm JE.
I do not have piston squirters nor will I as I'm in Australia and no-one is competent in doing it.
Lyndon
Old 04-29-2021, 01:00 AM
cylinders
Use an 84mm biral cylinder from a 2.2-2.4.Bore to 85mm and make a true 2.3 Litre.Nicasil of course.Fred
Old 04-29-2021, 06:00 AM
I have 2.0 S heads . I believe they wont fit.
Lyndon
Old 04-29-2021, 07:57 AM
You should be ok without squirters. 2.2S’s didn’t get squirters until 71.
Old 04-29-2021, 09:52 AM
Administrator
I'm far from an expert but I thought the reason for the factory's switch to squirters was the move to all-alum p/c's?
Old 04-29-2021, 08:38 PM
Puny Bird
Mark Henry's Avatar
I have a type 4 914 2.0 overbored to 2.6 with nickies/JE and 180HP, all I have is groves cut into the rods for "poor mans squirters". I do have an oversized oil pump to give me a boost in flow.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 04-30-2021, 07:01 AM
911R had ALU cylinders with chromal coating, no squirters. Normal production all ALU cylinders didn’t arrive till 73 2.7RS.
Old 04-30-2021, 08:29 AM
Try not, Do or Do not
Henry Schmidt's Avatar
The reason for squirters was to control piston temperatures.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-30-2021, 08:58 AM
Was this to allow for smaller piston to cylinder clearance? and reduce noise from piston slap?
Old 05-09-2021, 04:31 PM
otto_kretschmer's Avatar
as displacement increases, the pistons get bigger and with more power there will be more heat to get out of the engine
the center of the piston crown will be the hottest part of the piston because its the farthest from the rings
heat is absorbed from the combustion gases to the piston crown, the heat will flow to the rings and into the cylinder wall
heat will also flow from the piston to the gudgeon pin to the rod then down to the crank
the oil squirters spray oil onto the bottom side of the piston crown to keep the piston from getting too hot
Old 05-10-2021, 04:41 PM
PRO Motorsports
Tyson Schmidt's Avatar
Piston squirters allowed them to run thinner rings, improving sealing and reducing friction. The ring doesn’t have to conduct as much heat away from the piston crown to the cylinder so they were able to reduce the ring width of the 2nd ring to 1.5mm from 2mm.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 05-22-2021, 11:17 PM
That makes sense, Though the introduction of piston squirters did coincide with the first use of nikasil they weren't exclusive to it, So what you are saying is you don't need squirters is you have the thicker rings?
Old 05-29-2021, 08:06 PM
