otto_kretschmer's Avatar
Pauter rockers
I just noticed that Pauter makes rockers now for our aircooled cars.
https://pauter.com/parts/rockers/porsche/
has anyone used these?
just curious
I'm making baby steps to getting my car back on the road and I have several projects to clear first and I was just looking at Pauter's website
Old 04-27-2021, 09:41 PM
pauter rockers
I have used them with no issues.I am building a short stroke 3.0 right now with another set.66 stroke with 98mm bore.Great product.Fred
Old 04-28-2021, 04:05 AM
just curious
They look pretty schmick.. wonder how much they cost?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-28-2021, 04:36 AM
$2500/set
Old 04-28-2021, 04:41 AM
It's a 914 ...
stownsen914's Avatar
No personal experience but I understand respected shops are putting them in their race motors
Old 04-28-2021, 05:14 AM
No reverse gear in life
seems in line... I just used Schrick in a 3.0 high butterfly MFI motor and they were about 2,500 Euros
David Alstadter - There is no reverse gear in life!!!
74 911 2.7 Carrera 9114400120 - licht grün
71 911T 9111121235 - recreated as 2.8 RSR glasur blau (3.0 MFI)
73 911S 9113301270 - silber metallic (sold)
72 911T - bahia rot (2.8 RSR) SCCA ITGT 95 LA & SD champ (sold)
Old 04-29-2021, 02:21 AM
safe's Avatar
Anything must be better than what Porsche sells, they are horrible. At least a couple of years ago they came pre-pitted from the factory....
Magnus
Old 04-29-2021, 05:44 AM
Following
Old 04-29-2021, 06:32 AM
light rockers
I have seen the SCHRICK rockers.Very nice.There was also a company making Titanium a few years ago for $3800.00.What was there name?I thought they were in the UK?Ciao Fred
Old 04-29-2021, 05:07 PM
Navin Johnson
TimT's Avatar
Dopke Design used to make good rockers..
'69 911 GT-5
'75 914 GT-3
and others
Old 04-29-2021, 06:08 PM
was that extra?
Old 04-29-2021, 06:27 PM
safe's Avatar
was that extra?
Yep, the M471 lightweight rocker option!
Magnus
Old 04-29-2021, 11:31 PM
I've seen pitting on a few parts on my BMW motorcycles parts from the 70s
One head had a lot of pitting in the casting and I was having pinging issues but that was after making my R50 into a R60 and the R60s were prone to pinging. I finally fixed it by lowering the CR and putting stiffer springs on the advancement weights.
The original cam on my R90S had a pit on one of the bearing surfaces but not on a lobe and it wasn't a problem.
Both these bikes were from the era of when BMW Motorad was on the edge of going under so they probably let a lot of iffy parts pass thru.
Old 04-30-2021, 07:12 PM
Jeff Alton's Avatar
Did you consider getting the current set reground and re bushed? Or were there issues with that set that precluded that?
Cheers
www.turn3autosport.com
Old 04-30-2021, 10:20 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Cheers
Here is the process Supertec uses to reclaim old rockers:
We remove the old bushing
Black Oxide the rocker
Precision ream the bushing hole to exacting standards (Porsche just bores a crude hole)
Press in the new custom made DP-4 bushing and burnish to size.
Surface the contact pad for parallelization.
Blast with aluminum oxide and coat the contact pad with Moly dry film (TLML 2)
Treat the rocker to a Cryogenic conversion process
Clean adjuster threads with 8x1.0 forming tap.
All for $ 480 exchange.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-30-2021, 10:52 PM
safe's Avatar
Cheers
I don't remember if the original was to worn or if we didn't have any at all.
Magnus
Old 05-01-2021, 01:23 AM
KOH KOH is online now
Henry,
What is the lead time for reclaimed rockers? Since you said $480 exchange, does that mean you have them in stock already to go?
Thank you.
'87 Carrera, Granite Green, SW Chip, Dansk sport cat, Kuehl A/C
Old 05-06-2021, 01:20 PM
Originally Posted by KOH View Post
Henry,
Thank you.
We generally have restored sets on the shelf. These types of posts often cause a run on our products but we just completed a batch and we're good to go.
Henry Schmidt
Ph: 760-728-3062
Old 05-06-2021, 03:59 PM
Jeff Alton's Avatar
Henry,
Thanks, We have used many vendors to get them done. If you have on the shelf, we will send a couple of core sets down and take a couple of sets.
Cheers
Old 05-06-2021, 09:10 PM
The challenge is exchanging like for like.
We have 12 sets (or so) on the shelf but there are 6-7 different types of rockers.
We prefer to exchange the same type of rocker as the cores.
The differences are generally very small but the there does seem to be a quality difference. The later rockers seem like a lower quality cast iron and they are definitely heavier.
The move towards aftermarket forged rockers seems curious to me. Porsche used forged rockers in their early 2.0 production engines but discovered that over-revs resulted in catastrophic failures. The valves would hit the pistons and explosions would ensue. By using cast rockers, contact damage was mitigated by rocker breakage. By creating this breakaway mitigation, quite often you could replace the rocker without having the do any valve work. More than one track day was saved by simply replacing a broken rocker.
Forged rockers have their place when weight and enhanced ratios are deemed essential to performance requirements.
Henry Schmidt
Ph: 760-728-3062
Old 05-07-2021, 08:07 AM
