-   -   Damaged rocker - reuse or replace? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1093965-damaged-rocker-reuse-replace.html)
smarjoram 05-21-2021 07:40 AM
Have been sorting out broken head studs and found some damage on a rocker. It must have happened a while back as you cn see a difference in the polished surface of the cam (it's not scored or damaged in any way - just a different colour). Looks like it was maybe a casting defect.
Should I replace it. If so, do I need to worry about how the replacement will bed in? Does it matter if I use a new or 2nd hand part?
Thanks for your help.
http://forums.pelicanparts.com/uploa...1621607995.jpg
silverc4s 05-21-2021 07:57 AM
My vote - replace it. Used one should be fine.
Not an expert, but have rebuilt a few of these.
stownsen914 05-21-2021 08:02 AM
That looks like a chip. Granted most anything can be repaired - may not be worth it though.
Henry Schmidt 05-21-2021 08:02 AM
Replace it with a similar rocker.
There are a bunch of different rockers in the used market and new. Some are junk.
Shoot for an original rocket of matching configuration.
stownsen914 05-21-2021 08:03 AM
Should have the cam lobe assessed too
smarjoram 05-22-2021 12:48 PM
Thanks very much for the advice. Have got a replacement on the way.
BURN-BROS 05-23-2021 06:24 PM
I’ve never seen such a failure! Is that an original piece?
Determined 05-23-2021 09:36 PM
Replace, too far gone
