Damaged rocker - reuse or replace?
Have been sorting out broken head studs and found some damage on a rocker. It must have happened a while back as you cn see a difference in the polished surface of the cam (it's not scored or damaged in any way - just a different colour). Looks like it was maybe a casting defect.
Should I replace it. If so, do I need to worry about how the replacement will bed in? Does it matter if I use a new or 2nd hand part? Thanks for your help.
Crusty Conservative
My vote - replace it. Used one should be fine.
Not an expert, but have rebuilt a few of these.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
It's a 914 ...
That looks like a chip. Granted most anything can be repaired - may not be worth it though.
Try not, Do or Do not
Replace it with a similar rocker.
There are a bunch of different rockers in the used market and new. Some are junk. Shoot for an original rocket of matching configuration.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-21-2021 at 08:06 AM.. |
It's a 914 ...
Should have the cam lobe assessed too
Thanks very much for the advice. Have got a replacement on the way.
I’ve never seen such a failure! Is that an original piece?
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Replace, too far gone
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
