But if you simply add those gaskets so the full height of the cylinder head exceeds the factory length then you have to add gaskets to the key chain housing as well IIRC so the hole for the cam shaft in that housing is still properly aligned.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
J&S Electronics • Tech Articles
Ken 1986 930 2016 R1200RS |
Std base copper gaskets are 0.25mm.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
