Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
logician's Avatar
Hi Wayne,
> From what you say, the only thing I can gather is that the
> gauge we sell has two different gauges on it?
Yes exactly. The cylinder pressure gauge is at full scale at 36psi, and is marked in reverse, with 100 marked at zero scale, and 0 marked at full scale. Presumably, this is the same gauge that is used for the single gauge tester from that same manufacturer. The calibration gauge reads full scale at 100psi and is labled normally. Look at page 15 of your engine rebuild book for a picture of the instrument that PP sells. You can see how the gauges are marked differently. However, you actually have to use the gauge to see that their ranges are different.
> There must be a logical reason why the manufacturer did that,
> as I'm sure it would be cheaper to use two of the same...
Often in engineering, it's easier to make a small delta to something you already have. Then there is also specsmanship. Have you ever head the story about how railroad gauge evolved? It goes all the way back to the Romans...
I surmise that what the manufacturer did was simply add a second gauge to the existing single gauge instrument that they already had in production. The reason that they added a 100psi gauge instead of a 36psi gauge is so that it would appear to match the specs of the competing two gauge instruments. It fooled me. A reason for them not to use the same gauge for both is that the gauges would then have to be very accurate, and that would be more expensive. Their existing gauges are probably not that accurate, but because you aren't comparing their values, their accuracy is not very important.
Regarding why the single gauge instrument would have been designed with a 36psi gauge, I bet its a common gauge for tire pressure. BTW, I don't really know if that gauge is 36psi, I just know that the calibration gauge reports 36psi when the cylinder pressure gauge is at full scale. The gauge might very well be a 45psi gauge.
> Juan, you've done a great job researching this, but I think
> there are still some details missing.
I would like to understand what is missing. At this point I'm pretty convinced that the acceptable leakdown percentage is specific to the orifice size and the specs of a particular engine design. A larger engine is going to have a larger leakdown percentage at equivilent health. So while a 10% leakdown figure might be OK for a large auto engine, it would probably be very bad for a small motorcycle engine.
The reason for this is very simple. What a 10% leakdown figure really means is that the leak is (approximately) 10% of the size of the orifice. This falls out of the analysis given earlier. So if the orifice is approximately .8 sqmm in area, then the total leakage area is approximately .08mm.
If in fact, it doesn't work the way that I explain, then I would really like to understand why this explanation is wrong, and how it really does work. What is missing?
> Obviously if the orifice is sufficiently huge, then the two
> gauges will read the same.
Yes, I agree. That's exactly what the analysis says. So here's the equation for cylinder pressure (P) as a function of orifice area (O) and leakage area (L):
> P = 100 / (1 + L/O)
If the orifice (O) is huge, then L/O is very small. So:
> P = 100 / (1 + .00001) = 99.99999
So as you say, the cylinder pressure would be very close to the calibration pressure of 100psi when the orifice is large.
-Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011
ArtOfRoadRacing@gmail.com
SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11
Old 06-21-2003, 11:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #21 (permalink)
logician's Avatar
Hi,
For the record, here is why I believe the previous statement is true. Starting with the formula for leakage (L) as a function of cylinder pressure:
> L/O = (100-P)/P
Now the leakdown percentage at pressure P and calibration pressure 100psi is defined as:
> percentage = (100-P)
We substitue this into the formula for leakage area, and get:
> L/O = percentage/P
So for P equal to 90psi, leakdown percentage would be 10%:
> L/O = 10/90 = .11
Thus for leakdown of 10%, the equivilent leakage area is 11% of the orifice area. Here's a table that translates between leakdown % and orifice %. You can see that for smaller leakdown values, the orifice and leakdown percents are very close.
Leak
down Orifice
05% 05%
10% 11%
20% 25%
30% 43%
That is why I say that the leakdown percentage should be intepreted as (approximately) giving the leakage area as a percent of the orifice area. If all leakdown instruments standardize on the same size orifice (.04" seems to be common), then the leakdown % is actually an absolute measure of the size of the leak. It is not relative to any aspect of the engine.
Forget all those other intepretations of leakdown percentage as somehow a percentage of gas escaping (relative to what?). This interpretation is much more useful and direct. With this understanding it is easy to see why a smaller engine should have a smaller leakdown % measurement.
-Juan
Old 06-22-2003, 12:37 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #22 (permalink)
steve911sc's Avatar
Sorry I was in error on my posting..I went and looked it up and found that I have used .040" orifice not the #40 I said. I do like the analysis
of the system...good reading. As far as the size of engines..I have used the same tester on aircraft engines from 200 ci to 1340 ci. Some manufacturers allow more leakage than others. Must have something to do with the style of rings..etc.
82 911SC
71 911T...sort of, 2.2, S p&c, E crank, solex cams, weber carbs
Old 06-23-2003, 04:23 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #23 (permalink)
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
This is indeed a complicated question, if you look at the details. I'll reiterate again that the test is just one indicator, and shouldn't be an end-all answer to the health of your engine.
Orifice size would make a difference on the readings with respect to engine cylinder size. Let's assume that the engine is a huge locomotive engine with a huge cylinder size. That cylinder is going to act as a pressurized 'capacitor' in the dynamic system. The cylinder acts as a storage mechanism.
On the other hand, running a compression test on a model airplane engine would have a small cylinder size, and thus no capacitive effects. What does this mean? For an orifice size that is adjusted with respect to the size of the cylinder, nothing. For a fixed orifice size, then the readings will vary, as you will need to adjust the flow rate to compensate for the extra time it would take to reach steady state. I'm not explaining this well.
The bottomline is that the leakdown tester is useful for determining big problems (like 100% leakage), or big variations among cylinders. Like the compression tester, it is affected by many factors. As I state in the book, an engine with a leakdown test of 30% or more is probably experiencing problems. I also say not to use a single test by itself, but to go through the many tests and indicators in the book to figure out the health of your engine. It's not uncommon for engines that have been stored for many years to have bad leakdown numbers, but then leap to life when run for a short while. Another thing to remember is that the 911 engine is air cooled, and expands and contracts quite a bit when going from cold to hot. These clearances affect leak down testing too. Numbers achieved at cold may not have any relevance to the numbers measured when the engine is warm.
Bottomline? Go through the checklist and gather an aggregate picture of whether your engine needs a rebuild or not. I have also taken a closer look at the tool, and I feel that it does exactly what it is supposed to do.
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines101 Projects for Your Porsche Boxster & Cayman
Coming in 2012:
• 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997
Old 06-24-2003, 01:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #24 (permalink)
logician's Avatar
Hi Wayne,
In the interest of demystifying leak-down tests, I'd like to respond to your statement about "capacitive effects". The leak-down measurement is in fact static, so any such capacitive effects have no effect on the leak-down measurment or orifice size.
The leakdown test is measuring how much air blows by the rings and valves, and that is measured with the pressure in the cylinder at a steady and unchanging value. You are right that "capacitive effects" would affect how long it took for the pressure to reach that steady value, as the orifice restricts how quickly the pressure in the cylinder can change. But in practice, with the volumes and orifice sizes we are dealing with, that happens in fractions of a second, and so when you take the measurement, the pressure is static.
A good way to convince yourself that the volume of the cylinder won't affect the leak-down measurement is to consider whether the leakdown measurement would change if [by magic] you increased the stroke of your Porsche engine from 70.4mm to 704mm, without changing the bore. In this hypothetical situation, the volume of the cylinder would be increased by a factor of 10, thus your "capacitance" would be increased by a factor ot 10 also. However, the amount of leakage surface -- the circumference of the valves, and the circumference of the rings would not have changed, so the amount of air blowing by the rings and valves would not change. It is easy to understand that in this case, the leakdown measurement would not be affected, despite the increase in "capacitive effects".
Regarding how engine size affects leak-down measurement, I agree that size should affect the measurement. But as explained above, it is not because of any "capacitive effects". All other things being equal, a smaller engine should have a lower leakdown measurement than a larger engine because the rings and valves are smaller, so there is less length of sealing surfaces that can leak. You can see that since the size of the rings and valves are proportional to the bore of the engine, the leakdown measurement for different size engines (all other things being equal) will be proportional to the bore.
Regarding how engine type affects leakdown, that is an interesting question that I don't understand. Does the metal used for the cylinder and rings affect how much air leaks by? Does air-cooling vs. water cooling affect leakage, assuming the measurment was done correctly with the engine warmed up. How about the gap in the rings, or the springiness? What about 2 valve vs 4 valve? Perhaps the answers to these questions might give a reason why Porsche engines might have a different leak-down spec than other engines. Don't know. I'd like to learn more.
BTW, I think what you call "capacitive effects" might affect a compression test, i.e. a test that measures the peak pressure in the cylinder when you turn the engine over with the starter. Unlike the leakdown test, that compression test is dynamic, since the pressure in the cylinder is being cycled. No orifice is involved in that measurement. I don't know much about compression tests, perhaps that could be the subject of a future thread.
-Juan
Old 06-26-2003, 10:39 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #25 (permalink)
Well, my apologies in advance.
I used my brand new tester last night and, oh boy........#$#@$#$#.
Without going into details, I finally had to bypass the air regulator as it never stays the same pressure. I totally opened it and used the compressor in-line pressure/filter/regulator.
Juan,
What is also strange is that, assuming I am using the gauge correctly, the gauge has a built in 5% loss from the 0% setting to the time you hook up the quick-connections. Try this:
1. Set the gauge to 0%.
2. Using your finger, block the orifice.
3. Connect the hose to the gauge.
4. Gauge changes from 0% to 5%.
WHAT GIVES???????????
Theoretically, you would get 0% leak.
Old 10-22-2003, 05:04 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #26 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
$70 at pelican.
www.johnwalkersworkshop.com/ 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 10-22-2003, 07:23 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #27 (permalink)
Can't stop the addiction!
Slider79SC's Avatar
Ok,
so my question is; should a leakdown test be performed when the engine is cold? I know that a compression test done cold versus warm will be completely different so wouldn't that be the same for a leakdown test?
Am I missing something here????
RUF CTR 001 tribute in the works
Old 10-23-2003, 10:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #28 (permalink)
hot, with the rings oiled.
Old 10-23-2003, 11:02 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #29 (permalink)
Slider79SC's Avatar
So if I did it stone cold then my results were skewed?
Also, do you use 100psi or less for your testing?
I thought something might be up; my compression numbers were even and within specs for being at 5200 ft of altitude, but my leakdown numbers were weird.
I will warm the car up tonight and retest.
THANKS John, your help is ALLWAYS appreciated!!!!
Old 10-23-2003, 11:13 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #30 (permalink)
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I believe as wayne stated, air cooler motors rely heavily on their clearences because they expand significantly. Water cooled motors control their expansion better with cooler running heads and cylinders.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 10-23-2003, 01:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #31 (permalink)
Alan L's Avatar
OK, this is an old thread - but still good for information searches on leak down. So I will update it a bit with my latest experiment.
Am a bit concerned whether my track machine (930) is down on power - trying to identify a possible source. Did leakdown test first - got the following (first column)
#1 98 % 100 psi 92%
#2 96 105 86
#3 98 120 98
#4 100 110 98
#5 98 120 97
#6 100 120 98
These numbers were similar to a check a year or so ago on my same home made tester - 0.04" orifice.
Still not happy, I went looking for trouble and hooked up a comp tester. Second row of numbers.
Could not rationalise the numbers on 1&2. Thought about it and concluded the 0.04" orifice is a bit big for our engines (ie not sensitive enough). Is used for aircraft motors as a standard, and they have big donks.
So I filled my 0.04 in with solder and re drilled to 0.03" - about 60% surface area to previous - ie increased restriction by about 40% - this way the leaks will show up better - column 3.
So now the leak numbers confirm the comp numbers. Not sure if I am happier about this - prefer the first leak numbers. But in reality 0.04" diameter is hiding the issues for our size engines, until things get quite bad. If you want more sensitivity go for a smaller orifice.
#1&2 both have a bit of E valve leak, and cylinder leak.
Now I have to decide what to do. But in future I am sticking with 0.03" on my leakdown tool.
Alan
83 SC, 82 SC (Been gonna sell for 7 yrs), 82 930 (track) - Stock except for RarlyL8 race headers, 22/28 T bars, Digi WUR (currently in a box), Rarlyl8 Zork, modified 3LDZ, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust.
Old 06-07-2011, 09:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #32 (permalink)
Alan L's Avatar
Sorry - the column formatting got a bit screwed up in the posting.
Alan
Old 06-07-2011, 09:48 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #33 (permalink)
Alps Adventurer
Traveller's Avatar
Send a message via Skype™ to Traveller
Originally Posted by jgparker View Post
My question is what is the typical orifice size between gauge one and gauge two.
0.040 in (1.0 mm) orifice diameter, 0.250 in (6.4 mm) long, 60-degree approach angle. This applies to engines with piston diameters of less than 5 inches.
It does make a difference what the orifice diameter is.
I've seen posts where one owner took his car for a leakdown test to one garage, got some leakdown numbers and then took the same car to another garage and got different leakdown test numbers. All things being equal, chances are very good that both leakdown testers did not have the "standard" orifice size, or one did and the other didn't. A different orifice size will give you different leakdown numbers.
I've gone the Eastern Technology E2M leakdown tester route. That unit has a Master Orifice Valve to test the unit for accuracy. And at about $110, it isn't overly expensive.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 07-26-2012, 05:45 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #34 (permalink)
Alan L's Avatar
The 0.04" is an aircraft standard - typically big pistons. In my view it is a bit large for our engines. As you close the hole up, you get more determinative/sensitive numbers. For my race car I consider this important - pick up any issues early, rather than satisfy yourself all numbers are 95% or better.
I closed my orifice down to 0.03" from memory - it is another posting somewhere on this topic. (You can fill with solder and re drill with jet drill).
This made the unit much better at picking out differences between cylinders.
At 0.04", by the time you get below 90%, you really have noticeable blow by out somewhere - you could pick it up without the tester.
Alan
Old 07-26-2012, 11:30 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #35 (permalink)
Alps Adventurer
Traveller's Avatar
At least it is a standard and the only way you can compare numbers from one tester to another is if they are standardized.
BTW, The 0.040" orifice standard if for 5" and smaller pistons. 993 pistons are 4". For pistons larger than 5", the spec is 0.060". Originally, they used displacement instead of piston diameter, but I guess they figured that one out fast enough.
As for many of the leak down testers advertized, I do not see any specs listed.
All the best,
Alex
Old 07-26-2012, 11:53 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #36 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
