-   -   How much Loctite should i get (http://forums.pelicanparts.com/911-engine-rebuilding-forum/109868-how-much-loctite-should-i-get.html)
brandett 05-08-2003 05:14 AM
Loctite 574 is sold in 25 ml bottles here, seems very little. How much do i need to assembly the whole engine ??
TimT 05-08-2003 07:02 AM
25ml should be plenty.When you use loctite you only use a drop or two on threaded prtion of the bolt.
Edit... ooops I though you meant loctite thread red.. not the case sealer
mah bad
brandett 05-08-2003 07:05 AM
Ok, sorry, the Loctite 574 is to be used as case sealant when mating the case halves together and cams etc. As recommended by the book..
Doug Zielke 05-08-2003 07:21 AM
Hi Peter,
They sell 574 in 50ml bottles here. That should be ample, especially when you spread it as per factory instructions (ie: thinly, with a tiny, velour roller.)
PS: The stuff I promised to send you was mailed on Monday.
brandett 05-08-2003 07:24 AM
Thanks Doug,
Will order two bottles then, dont want to run out in the middle of the assembly.
Still waiting by the mailbox but I know it takes over a week sometimes. Will let you know when it arrives.
