Loctite 574 is sold in 25 ml bottles here, seems very little. How much do i need to assembly the whole engine ??
Navin Johnson
25ml should be plenty.When you use loctite you only use a drop or two on threaded prtion of the bolt.
Edit... ooops I though you meant loctite thread red.. not the case sealer mah bad
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 05-08-2003 at 07:34 AM.. |
Ok, sorry, the Loctite 574 is to be used as case sealant when mating the case halves together and cams etc. As recommended by the book..
Senior Member
Hi Peter,
They sell 574 in 50ml bottles here. That should be ample, especially when you spread it as per factory instructions (ie: thinly, with a tiny, velour roller.) PS: The stuff I promised to send you was mailed on Monday.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Thanks Doug,
Will order two bottles then, dont want to run out in the middle of the assembly. Still waiting by the mailbox but I know it takes over a week sometimes. Will let you know when it arrives. |
