Long block weight?
Gents,
Any idea how much a 911 long block weights? Im thinking ~200 lbs. How would you package? Strapped on a pallet ? Who would you use to ship? ????? Thanks, Dave |
Our Mr. Verburg posted this summary some time ago. I don't think the weights changed much:
kg lbs models Source 182 400 2.4L E, S, RS 1972-73 Tech. Spec. book 183 403 2.4L T 1972-73 Tech. Spec. book 182 400 2.7L 1974 unknown 200 440 2.7L 1975-1977 Aichle - 911 Engines 190 419 78-83 930/09,19,10 78-81 78-81 & 82-83 Tech Spec. book 200 441 78-83 930/03-08,13-17 78-81 & 82-83 Tech Spec. book 190 462 3.0L 1980-82 Aichle - 911 Engines 190 418 3.0L SC w/ SSI & heat,w/o AC measured 219 483 84-87 930/20,26 84-87 Tech Spec. book 220 485 84-87 930/21,25 84-87 Tech Spec. book 219 482 3.2L 1987 - 1988 Aichle - 911 Engines 238 524 964 89-94 M64/01,02 ROW &US 964 Tech Spec. book 226 497 M64/03 RS 964 Tech Spec. book 275 605 M30/69 3.3L 964 Tech Spec. book 276 608 M64/50 3.6L 964 Tech Spec. book 232 510 M64/05-08 993 Tech Spec. book 221 487 M64/20 993RS v-ram w/o ZMS 993 Tech Spec. book 230 507 M64/20 993RS v-ram w/ ZMS 993 Tech Spec. book A long block typically doesn't include intake, exhaust or engine harnesses, so some extrapolation is needed from the above numbers. Sherwood |
Strap to a pallet. Better to build a box around it too. LTL carrier.
Shipping class "70."
Thanks for the comments.
Are there companies that specialize in shipping engines? |
I agree with Mark. Freightquote has worked well for me.
If you are shipping it to sell , ratchet strap loose to a pallet whilst you take measurements for wooden supports underneath engine .
Once it’s supported and snug , do the same by building a wooden frame over the top . Then box it . This can be s raps of wood from construction buddies or Home Depot etc to keep costs down . If you are shipping it to be worked on elsewhere then returned , either design everything to be reusable and easy to reinstall correctly , or even buy a used flight case and build a support system into that . |
| All times are GMT -8. The time now is 05:23 AM. |
