Dave Kost's Avatar
Long block weight?
Gents,
Any idea how much a 911 long block weights? Im thinking ~200 lbs.
How would you package? Strapped on a pallet ?
Who would you use to ship? ?????
Thanks,
Dave
Dave K
Old 08-19-2021, 10:25 AM
Our Mr. Verburg posted this summary some time ago. I don't think the weights changed much:
kg lbs models Source
182 400 2.4L E, S, RS 1972-73 Tech. Spec. book
183 403 2.4L T 1972-73 Tech. Spec. book
182 400 2.7L 1974 unknown
200 440 2.7L 1975-1977 Aichle - 911 Engines
190 419 78-83 930/09,19,10 78-81 78-81 & 82-83 Tech Spec. book
200 441 78-83 930/03-08,13-17 78-81 & 82-83 Tech Spec. book
190 462 3.0L 1980-82 Aichle - 911 Engines
190 418 3.0L SC w/ SSI & heat,w/o AC measured
219 483 84-87 930/20,26 84-87 Tech Spec. book
220 485 84-87 930/21,25 84-87 Tech Spec. book
219 482 3.2L 1987 - 1988 Aichle - 911 Engines
238 524 964 89-94 M64/01,02 ROW &US 964 Tech Spec. book
226 497 M64/03 RS 964 Tech Spec. book
275 605 M30/69 3.3L 964 Tech Spec. book
276 608 M64/50 3.6L 964 Tech Spec. book
232 510 M64/05-08 993 Tech Spec. book
221 487 M64/20 993RS v-ram w/o ZMS 993 Tech Spec. book
230 507 M64/20 993RS v-ram w/ ZMS 993 Tech Spec. book
A long block typically doesn't include intake, exhaust or engine harnesses, so some extrapolation is needed from the above numbers.
Sherwood
Old 08-19-2021, 11:16 AM
Strap to a pallet. Better to build a box around it too. LTL carrier.
Old 08-19-2021, 11:29 AM
Shipping class "70."
Old 08-19-2021, 12:42 PM
Dave Kost's Avatar
Thanks for the comments.
Are there companies that specialize in shipping engines?
Dave K
Old 08-19-2021, 04:40 PM
The 9 Store
I use a rep at freightquote. He has shipped at least a dozen engines for me and more for my friends. Great job every time. I have no financial or personal affiliation but pm me if you want his contact info. mark
All used parts sold as is.
Old 08-20-2021, 04:13 PM
Dave Kost's Avatar
PM sent
Dave K
Old 08-21-2021, 07:01 AM
I agree with Mark. Freightquote has worked well for me.
Old 08-21-2021, 10:18 AM
If you are shipping it to sell , ratchet strap loose to a pallet whilst you take measurements for wooden supports underneath engine .
Once it’s supported and snug , do the same by building a wooden frame over the top .
Then box it .
This can be s raps of wood from construction buddies or Home Depot etc to keep costs down .
If you are shipping it to be worked on elsewhere then returned , either design everything to be reusable and easy to reinstall correctly , or even buy a used flight case and build a support system into that .
Old 08-21-2021, 07:46 PM
