-   -   Can you put intermediate / distr gear on GT3 crank (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1105097-can-you-put-intermediate-distr-gear-gt3-crank.html)
JoeMag 10-24-2021 08:08 AM
Thinking of next rev of my motor and was wondering if you can put the intermediate shaft gear w distributor gear on a GT3 crank?
One less thing I'd need to change if I can keep the twin plug dizzy.
Henry Schmidt 10-25-2021 10:53 AM
You can with some simple machine work. I'm not at the shop so I can't remember the exact process but it can be done.
stanglife 02-21-2022 08:26 AM
TTT - any details? Looking at this and want to understand what I need to ask of machinist, if anything?
Jonny042 02-21-2022 04:45 PM
I think it's pretty simple. In the GT3 application it has a spacer instead of a distributor drive gear.
Note the 959 part number!!! Also the 901 part numbers in there, too.http://forums.pelicanparts.com/uploa...1645490685.jpg
stanglife 02-24-2022 04:57 AM
Interesting. I've heard that it drops right in but have also heard from others there is some machining required - just want to get the final answer ;)
