JoeMag's Avatar
Can you put intermediate / distr gear on GT3 crank
Thinking of next rev of my motor and was wondering if you can put the intermediate shaft gear w distributor gear on a GT3 crank?
One less thing I'd need to change if I can keep the twin plug dizzy.
Old 10-24-2021, 08:08 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You can with some simple machine work. I'm not at the shop so I can't remember the exact process but it can be done.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-25-2021, 10:53 AM
TTT - any details? Looking at this and want to understand what I need to ask of machinist, if anything?
Old 02-21-2022, 08:26 AM
(man/dude)
Jonny042's Avatar
I think it's pretty simple. In the GT3 application it has a spacer instead of a distributor drive gear.
Note the 959 part number!!! Also the 901 part numbers in there, too.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 02-21-2022, 04:45 PM
Interesting. I've heard that it drops right in but have also heard from others there is some machining required - just want to get the final answer
Old 02-24-2022, 04:57 AM
