-   -   Need spark plug recommendation (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1105555-need-spark-plug-recommendation.html)
dpegan 10-30-2021 10:36 AM
I am finishing a new engine build and need your recommendation for what spec spark plugs to run in the engine. Some information on build:
3 liter
Stock heads and valve size
Aascomotorsports valve springs and retainers
Compression ratio 10.5 : 1
Cams Elgin 306/288–102
Twin plug
S spec MFI
Thanks in advance for your responses
Cheers,
Dan
Walt Fricke 11-02-2021 05:03 PM
Plugs aren't all that expensive. I'd start on the cold side, maybe NGK 7s or 8s? And see how they do. I think only if you run way too hot a plug could you get into some real trouble.
dpegan 11-03-2021 07:58 AM
Walt
Thanks for the advise.
infraredcalvin 11-03-2021 10:04 PM
I’ve been having trouble getting BP7ES even the resistor version (BPR7ES), which my engine likes. I got some 8s and they seem to fire well.
