3.0 cylinder problem
Hi
We have a 77 turbo with a blown cylinder gasket. The outer "ring" of the cylinder has some problem What should we do with it? Our machine workshop confused ![]() ![]()
hmmm... to me, that looks like it's ready for the bin. Need to find a replacement cylinder.
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Try not, Do or Do not
Head stud failure. The cylinder pressure caused the head to lift and the gasket squeezed out. If the rings are in tact, it probably wasn't caused by detonation.
We have good used cylinders if you are looking for a replacement.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
The previous mechanic forgot to connect the wastegate.
18 head stud was broken |
Banned
thanks for the awesome information.
