2.2 crank
can you balance a 2.2 t crankshaft?
Old 12-23-2021, 05:30 AM
Under the radar
Trackrash's Avatar
Depends what you mean. Why do you ask?
Spin balance, sure. But most 911 cranks are very good from the factory.
Do you have a T crank or an E or S crank?
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-23-2021, 05:08 PM
Thought he said T crank which is the only non counterweighted 66mm one from that year. In spite of not having counterweights zI would think any good crank shop like Marine or CCR could balance with their machines. If it were me I’d contact Marine Crank to get that done.
Old 12-23-2021, 07:46 PM
always heard never use a t crankshaft because it is not counterweighted
seems like a good shop could do it
did porsche not do it because of cost, or what?
Old 12-24-2021, 05:16 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Cost and no expectation of higher RPMs.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-24-2021, 08:11 AM
It's a 914 ...
stownsen914's Avatar
Sounds like we may be mixing the terms balanced and counterweighted. A non-counterweighted crank is balanced (or at least it is as far as I know). Making it counterweighted, while technically possible by welding on counterweights, probably wouldn't make sense to do.
Old 12-24-2021, 12:13 PM
No, it's *always* use a t crank because it's not counterweighted. Spins up even faster than a lightweight flywheel.
No good for sustained high revs though, i.e. over 6,500.
Sent from my SM-G988B using Tapatalk
Old 12-24-2021, 02:41 PM
Puny Bird
Mark Henry's Avatar
I always balance the complete rotating assembly, I even recommend it on stock engines.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-25-2021, 03:52 PM
