-   -   Grub screw? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1109809-grub-screw.html)
SunburntLobster 01-01-2022 12:54 PM
Grub screw?
Rebuilding my engine and trying to remember where this bit came from. Anyone recognise it? Cheers
http://forums.pelicanparts.com/uploads26/PXL_20220101_1457406201641070451.jpg[/img]
Mark Henry 01-01-2022 01:22 PM
You clipped the front code off your linky...fixed it for you.
Plus it's the grub screw from a shift rod linkage.
http://forums.pelicanparts.com/uploa...1641070451.jpg
RobFrost 01-01-2022 01:55 PM
You probably have two of those. Screw them into the shift rod linkage now with a spot of thread glue, so as not to lose them.
Sent from my SM-G988B using Tapatalk
Mark Henry 01-01-2022 02:12 PM
^ agree
You're suppose to replace them every time, there's a little nylon button in the screw threads, one use only.
I clean the threads, use what ever loctite I have (red) and warm the screw up with a torch before removing it.
There's an easy release I've used (blue) and it works as well, the trick is those clean threads.
SunburntLobster 01-01-2022 10:28 PM
Brilliant! Thanks all, I was scanning the parts diagram but couldn't find it. Thanks for the advice on reusing it.
Cheers Jack
faapgar 01-03-2022 04:18 PM
Grub screw
Actually the one to use is 65-68.It has a square 8mm head with a hole for safety wire.No loctite needed.Fred
