-   -   "0" vs. "1" timing gears ? mix or match ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1110071-0-vs-1-timing-gears-mix-match.html)
ty901 01-05-2022 04:38 PM
a buddy is building a 2.2L engine from random parts.
the factory parts manual lists 2 versions of the steel timing gear that lives on the crank.
his intermediate shaft gear is marked '0'
1) is it critical that he use the corresponding steel gear ?
2) does the steel gear carry the same '0' mark ?
input appreciated.
TIA
RobFrost 01-06-2022 01:19 AM
No idea the answer, but is this ignition or valve timing? They made cars with Bosch snd Marelli distributors, maybe they had different drive gear?
Sent from my SM-G988B using Tapatalk
dannobee 01-06-2022 04:07 AM
Look in the factory workshop manual. The "0" and "1" gears can be swapped around to set the gear backlash. There's a chart in the manual.
gled49 01-06-2022 08:47 AM
What dannobee says, sometimes mix and match required to set proper backlash.
ty901 01-06-2022 03:47 PM
thanks guys... I'll check it out. BTW, are these gears stamped similar to the gear on the intermediate shaft ?
dannobee 01-06-2022 04:23 PM
Yes, and the case is usually stamped, too. Near the fan housing and crank pulley.
Rosco_NZ 01-08-2022 10:20 AM
This works well in theory .. but anyone managed to source a ‘1’ stamped IS gear ..?? Not sure whether these are available ..
Flat6pac 01-08-2022 02:00 PM
You have to match the number on the case
0 or 1, I have either if needed.
Bruce
djpateman 01-09-2022 04:38 AM
As Bruce says, the matching # is stamped on the case; example here:
http://forums.pelicanparts.com/uploa...1641731910.jpg
Rosco_NZ 08-04-2023 09:38 AM
This goes out the window once the case halves are flattened and align bored.
dannobee 08-04-2023 10:15 AM
As does the distributor drive gear backlash. Although that would make a good time to update to EFI and COP or distributorless ignition.
Henry Schmidt 08-05-2023 12:58 PM
Of course we have them....
http://forums.pelicanparts.com/uploa...1691265418.JPG
