"0" vs. "1" timing gears ? mix or match ?
a buddy is building a 2.2L engine from random parts.
the factory parts manual lists 2 versions of the steel timing gear that lives on the crank. his intermediate shaft gear is marked '0' 1) is it critical that he use the corresponding steel gear ? 2) does the steel gear carry the same '0' mark ? input appreciated. TIA
Unclear on the concept ? Let's see if I can help. 1) You are NOT in the "fast lane" and... 2) You are NOT going "fast enough". **News Flash** You're in the Passing Lane. Any questions ? |
No idea the answer, but is this ignition or valve timing? They made cars with Bosch snd Marelli distributors, maybe they had different drive gear?
Sent from my SM-G988B using Tapatalk |
Look in the factory workshop manual. The "0" and "1" gears can be swapped around to set the gear backlash. There's a chart in the manual.
What dannobee says, sometimes mix and match required to set proper backlash.
thanks guys... I'll check it out. BTW, are these gears stamped similar to the gear on the intermediate shaft ?
Yes, and the case is usually stamped, too. Near the fan housing and crank pulley.
Rosco_NZ
This works well in theory .. but anyone managed to source a ‘1’ stamped IS gear ..?? Not sure whether these are available ..
You have to match the number on the case
0 or 1, I have either if needed. Bruce |
As Bruce says, the matching # is stamped on the case; example here:
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Rosco_NZ
This goes out the window once the case halves are flattened and align bored.
As does the distributor drive gear backlash. Although that would make a good time to update to EFI and COP or distributorless ignition.
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
