Send a message via Yahoo to ldangelo
Cleaning oil cooler and oil tank
Hi folks,
I want to know if it is O.K. to clean my oil cooler (engine mounted) and oil tank in a parts cleaner containing kerosene?
Is there a better way to clean these parts yourself?
Thanks in advance,
-LeoD
85 Slantnose 930
Old 05-17-2003, 06:20 PM
Irrationally exuberant
ChrisBennet's Avatar
Rinsing out an oil cooler will not be enough if the cooler is being cleaned due to an engine failure. See this recent thread about cleaning oil coolers
-Chris
Old 05-18-2003, 06:35 AM
Thanks for the reply chris,
I did'nt have an engine "failure". I'm rebuilding a leaky motor and taking the opportunity to do a bunch of performance upgrades.
I decide that I might as well have them ultrasonically cleaned while I'm at it...
Thanks again,
-LeoD
85 Slantnose 930
Old 05-18-2003, 04:40 PM
You going to have the motor done in time for NHIS this weekend?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-18-2003, 06:59 PM
Not sure how most shops ultrasonically clean, but I'd suggest they consider using heated/hot solvent during the cleaning process. The higher temperature might increase the passage size to allow more trapped particles to escape.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 05-18-2003, 10:33 PM
Banned
snowman's Avatar
I would have the parts "professionally" ultrasonically cleaned. the things just to darn expensive to do otherwise.
Old 05-18-2003, 10:38 PM
