Cleaning oil cooler and oil tank
Hi folks,
I want to know if it is O.K. to clean my oil cooler (engine mounted) and oil tank in a parts cleaner containing kerosene? Is there a better way to clean these parts yourself? Thanks in advance, -LeoD
85 Slantnose 930 |
Irrationally exuberant
Rinsing out an oil cooler will not be enough if the cooler is being cleaned due to an engine failure. See this recent thread about cleaning oil coolers
-Chris |
Thanks for the reply chris,
I did'nt have an engine "failure". I'm rebuilding a leaky motor and taking the opportunity to do a bunch of performance upgrades. I decide that I might as well have them ultrasonically cleaned while I'm at it... Thanks again, -LeoD
85 Slantnose 930 |
You going to have the motor done in time for NHIS this weekend?
![]() -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Not sure how most shops ultrasonically clean, but I'd suggest they consider using heated/hot solvent during the cleaning process. The higher temperature might increase the passage size to allow more trapped particles to escape.
Sherwood Lee http://members.rennlist.org/911pcars |
Banned
I would have the parts "professionally" ultrasonically cleaned. the things just to darn expensive to do otherwise.
