rebuild porn
Old 01-03-2022, 06:20 AM
xjoegtix's Avatar
Old 01-07-2022, 06:24 AM
Engine Porn
Old 01-07-2022, 01:03 PM
ollie's
got to endorse ollie's for the repair work on my case
from this...
to this...
Old 01-08-2022, 08:22 AM
onboost's Avatar
Any of you guys.. dannobee, hcrubg care to tell us anything about your builds or is this strictly a picture show?
Thx
RGruppe #180
Old 01-13-2022, 09:35 AM
David's Avatar
Who did the pretty head work?
Old 01-18-2022, 08:15 AM
Bill @ Xtreme did the CNC porting and guide work. I did the final seat work, blending, flowbench work, and assembly. Heads flow just under 300cfm at 0.500" and 200cfm at 0.500" More impressively (at least to cylinder head guys), they flow over 200cfm and 150cfm starting at 0.250" Valves are 50.5mm and 42.5mm Inconel. Beehive springs and lightweight retainers. Pauter rockers.
Carrera intake with 82mm GT3 DBW throttle body and adapter, with 4bar TMap.
More head pics here.
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1088251-beehive-valve-springs.html
Old 01-18-2022, 06:37 PM
Dannobee: Beautiful job! A few questions- Whose cylinder head studs are you using? How much HP & TQ do you expect from this engine?
Re: head work- does all this porting/flowing work help a modestly improved engine, or is it more for a max build?
Old 01-19-2022, 08:43 AM
Stock 3.3L turbo head for comparison
Old 01-22-2022, 04:09 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Thx
Check any of my engine posts and you'll find an attempt to enlighten as well as illuminate.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-25-2022, 09:39 AM
