-   -   2.5 L piston question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1111135-2-5-l-piston-question.html)
NickP 01-20-2022 05:53 PM
Can a 2.4 L mag case accept an 86.7mm piston without enlarging the spigots? Thanks
jbell959 01-20-2022 06:16 PM
If you are referring to the Mahle 86.7 pistons and cylinders then you either need to enlarge the spigots or turn down the cylinders. I used those P&Cs in one of my 2.5s and I elected to turn down the cylinders to fit the 2.4 spigots.
NickP 01-20-2022 07:12 PM
Yes, the Mahle 86.7’s. Thanks.
Henry Schmidt 01-21-2022 10:45 AM
Originally Posted by jbell959 (Post 11583274)
if you are referring to the mahle 86.7 pistons and cylinders then you either need to enlarge the spigots or turn down the cylinders. I used those p&cs in one of my 2.5s and i elected to turn down the cylinders to fit the 2.4 spigots.
+1
jbell959 01-21-2022 10:51 AM
Originally Posted by Henry Schmidt (Post 11583963)
+1
Henry... Great to see you back in action. I should have said, Henry built me a 2.5 with the 86.7mm Mahles and we elected to turn down the cylinders. 🙂
Makes a great engine. Cheers
NickP 01-21-2022 12:45 PM
Can’t get a better endorsement than that! Thanks Henry. I have a feeling it’s going to be a challenge to acquire the parts I need: heads, pistons and cylinders. Any leads or ideas are appreciated.
Henry Schmidt 01-21-2022 01:09 PM
Call us. We have thousands a early 911 engine parts to build any of the conventional or innovative engine configurations that 50 years of developed has innodated the enthusiasts imagination.
Henry Schmidt 01-21-2022 01:32 PM
Originally Posted by jbell959 (Post 11583970)
Henry... Great to see you back in action. I should have said, Henry built me a 2.5 with the 86.7mm Mahles and we elected to turn down the cylinders. ��
Thanks John
You owe me a visit. Give me a minute and we'll find a day to connect, Your 915 is ready if you want to pick it up.
NickP 01-21-2022 01:55 PM
Thanks Henry. I just asked Glenn Roberts to give you a call. He know what we are up to.
