-   -   Looking for P201 Engine Yoke Source (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1111213-looking-p201-engine-yoke-source.html)
winders 01-23-2023 10:41 PM
I have one of these and it works great:
https://www.walmart.com/ip/Pittsburgh-Automotive-Foldable-Engine-Stand-2000-lb-Capacity-Heavy-Duty-69521/514100311
It folds up into a compact rollable form and is more than strong enough. Plus, I can get my HF table in place to put the engine on or get it off the stand.
Emo993 01-24-2023 03:36 AM
Or if you want to weld one up, this was copied from Jerry Woods engine build shop. I had three made.http://forums.pelicanparts.com/uploa...1674560156.jpg
FA-18C 01-25-2023 08:02 AM
Thanks for input - managed to stumble across a stand that is exactly what you have recommended. 2nd best part is that it is free... :)
MichaelSJackson 01-26-2023 08:47 AM
I'm working in a small 1 car garage. The collapsible stand (from HF) is a blessing. When not in use, it is tucked away in a corner. The head also allows me to use a partial ring; instead of the full yoke. I had to cut some spacers, from iron plumbing pipe to mount the adapter and the first time, it took a couple of iterations in getting it centered just right.
I lift the engine with a chain hoist and trolley, suspended from an 'I' beam. A little overkill, but makes the job easy.
Michael J
'78 SC w/Bitz
'67 C-10 short step side
toddu 01-28-2023 06:44 PM
Where is the location of the need?
