Racer
I have one of these and it works great:
https://www.walmart.com/ip/Pittsburgh-Automotive-Foldable-Engine-Stand-2000-lb-Capacity-Heavy-Duty-69521/514100311 It folds up into a compact rollable form and is more than strong enough. Plus, I can get my HF table in place to put the engine on or get it off the stand.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Or if you want to weld one up, this was copied from Jerry Woods engine build shop. I had three made.
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
Senior Member
Thanks for input - managed to stumble across a stand that is exactly what you have recommended. 2nd best part is that it is free...
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
I'm working in a small 1 car garage. The collapsible stand (from HF) is a blessing. When not in use, it is tucked away in a corner. The head also allows me to use a partial ring; instead of the full yoke. I had to cut some spacers, from iron plumbing pipe to mount the adapter and the first time, it took a couple of iterations in getting it centered just right.
I lift the engine with a chain hoist and trolley, suspended from an 'I' beam. A little overkill, but makes the job easy. Michael J '78 SC w/Bitz '67 C-10 short step side |
Where is the location of the need?
