-   -   Walk down memory lane. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1111404-walk-down-memory-lane.html)
Henry Schmidt 01-24-2022 11:25 AM
A costumer has added this engine to his wish list so I thought we would take the temperature of the forum.
Originally Posted by Henry Schmidt (Post 7430625)
Supertec 3.1 liter Short Stroke 9000 RPM 2 valve
1982 930 Turbo case (GT3 squirters)
Shuffle pins
Boat Tail
Supertec SuperCrank billet 66mm full cross drilled
R&R billet connecting rods (GT3 config: 53mm big end, 21mm small end & 130mm oal)
GT3 Bearings coating by Calico Coating
996 TT oil pump
Racing IWIS chains
Supertec idler arms
964 steel countershaft
Supertec Head studs
LN Nickie cylinders 100mm
Supertec 906 cooling tin
10:1 JE FSR pistons, 60 grams lighter than conventional pistons
Custom DC 80 cams
Early forged rockers w/dry film pads
Extreme Cylinder heads
Port Flow Analyzer v3.0 EXTREME CYLINDER HEADS
Test Comments:
Vlv Dia
1.850"
1.575"
Stem Dia.31"
Lift Range Test Flow Leak Corr Pres Pres CFM
Int #1 .100 4 28.00 34.00 .0 67.7
Int #1 .200 4 28.00 79.00 .0 157.2
Int #1 .300 5 28.00 73.50 .0 216.8
Int #1 .400 5 28.00 84.00 .0 247.8
Int #1 .500 5 28.00 89.50 .0 264.0
Exh #1 .100 4 28.00 25.00 .0 51.3
Exh #1 .200 4 28.00 53.00 .0 108.7
Exh #1 .300 4 28.00 75.00 .0 153.8
Exh #1 .400 4 28.00 87.50 .0 179.4
Exh #1 .500 4 28.00 93.00 .0 190.7
50mm PMO Carbs (manifolds 41 x 50mm)
Burnham Motorsport Twin plug distributor
Burnham Motorsport sump cover
Series 900 fan shroud
Supertec Power Pulley
Supertec RSR flywheel
http://forums.pelicanparts.com/uploa...1368047314.jpg
http://forums.pelicanparts.com/uploa...1368047340.jpg
http://forums.pelicanparts.com/uploa...1368047362.jpg
http://forums.pelicanparts.com/uploa...1368047383.jpg
http://forums.pelicanparts.com/uploa...1368047451.jpg
http://forums.pelicanparts.com/uploa...1368047466.jpg
http://forums.pelicanparts.com/uploa...1368047483.jpg
http://forums.pelicanparts.com/uploa...1368047505.jpg
http://forums.pelicanparts.com/uploa...1368047614.jpg
http://forums.pelicanparts.com/uploa...1368047681.jpg
Henry Schmidt 01-24-2022 11:47 AM
I believe this project customer is leaning towards High butterfly MFI.
Old school with a modern flair. Mostly, technical innovations
http://forums.pelicanparts.com/uploa...1643053822.jpg
TibetanT 01-24-2022 05:26 PM
OMG!
Henry,
That is incredible. Lucky customer!
My temperature right now is: overheated
Thanks for sharing.
SmileWavy
Cairo94507 01-27-2022 06:50 AM
If I ever win the lottery I want Henry to build me an engine for my 914-6. Man, that is beautiful. :)
Emo993 01-31-2022 07:39 AM
That is beautiful Henry. Will that be able to run on street gas with the 10 to 1 CR. Best, Mark. Sorry, just saw the twin plug. Very lucky customer.
911dhutch 02-04-2022 09:59 AM
That's a WOW build
DIABLO 914_6 02-05-2022 06:23 AM
Beautiful engine Henry! I have had most of the stuff to build both 3.1 & 2.5 short stroke MFI engines for a long time. Both were on my bucket list, but life events sometimes get in the way. I hope you are feeling better.
http://forums.pelicanparts.com/uploa...1644070088.JPG
http://forums.pelicanparts.com/uploa...1644070088.jpg
al lkosmal 02-06-2022 09:25 AM
henry,
I always read your posts....you show the coolest stuff.
regards,
al
