Try not, Do or Do not
Henry Schmidt's Avatar
Walk down memory lane.
A costumer has added this engine to his wish list so I thought we would take the temperature of the forum.
Originally Posted by Henry Schmidt View Post
Supertec 3.1 liter Short Stroke 9000 RPM 2 valve
1982 930 Turbo case (GT3 squirters)
Shuffle pins
Boat Tail
Supertec SuperCrank billet 66mm full cross drilled
R&R billet connecting rods (GT3 config: 53mm big end, 21mm small end & 130mm oal)
GT3 Bearings coating by Calico Coating
996 TT oil pump
Racing IWIS chains
Supertec idler arms
964 steel countershaft
Supertec Head studs
LN Nickie cylinders 100mm
Supertec 906 cooling tin
10:1 JE FSR pistons, 60 grams lighter than conventional pistons
Custom DC 80 cams
Early forged rockers w/dry film pads
Extreme Cylinder heads
Port Flow Analyzer v3.0 EXTREME CYLINDER HEADS
Test Comments:
Vlv Dia
1.850"
1.575"
Stem Dia.31"
Lift Range Test Flow Leak Corr Pres Pres CFM
Int #1 .100 4 28.00 34.00 .0 67.7
Int #1 .200 4 28.00 79.00 .0 157.2
Int #1 .300 5 28.00 73.50 .0 216.8
Int #1 .400 5 28.00 84.00 .0 247.8
Int #1 .500 5 28.00 89.50 .0 264.0
Exh #1 .100 4 28.00 25.00 .0 51.3
Exh #1 .200 4 28.00 53.00 .0 108.7
Exh #1 .300 4 28.00 75.00 .0 153.8
Exh #1 .400 4 28.00 87.50 .0 179.4
Exh #1 .500 4 28.00 93.00 .0 190.7
50mm PMO Carbs (manifolds 41 x 50mm)
Burnham Motorsport Twin plug distributor
Burnham Motorsport sump cover
Series 900 fan shroud
Supertec Power Pulley
Supertec RSR flywheel
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-24-2022, 11:25 AM
I believe this project customer is leaning towards High butterfly MFI.
Old school with a modern flair. Mostly, technical innovations
Henry Schmidt
Ph: 760-728-3062
Old 01-24-2022, 11:47 AM
TibetanT's Avatar
OMG!
Henry,
That is incredible. Lucky customer!
My temperature right now is: overheated
Thanks for sharing.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 01-24-2022, 05:26 PM
Cairo94507's Avatar
If I ever win the lottery I want Henry to build me an engine for my 914-6. Man, that is beautiful.
'71 914-6 #0372
'17 Macan GTS
Old 01-27-2022, 06:50 AM
Emo993's Avatar
That is beautiful Henry. Will that be able to run on street gas with the 10 to 1 CR. Best, Mark. Sorry, just saw the twin plug. Very lucky customer.
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 01-31-2022, 07:39 AM
That's a WOW build
Old 02-04-2022, 09:59 AM
Beautiful engine Henry! I have had most of the stuff to build both 3.1 & 2.5 short stroke MFI engines for a long time. Both were on my bucket list, but life events sometimes get in the way. I hope you are feeling better.
Old 02-05-2022, 06:23 AM
al lkosmal's Avatar
henry,
I always read your posts....you show the coolest stuff.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 02-06-2022, 09:25 AM
