It's a 914 ...
stownsen914's Avatar
Identifying brand of titanium valve
I need to replace a titanium intake valve due to some gouges on the stem. I can’t identify the manufacturer, no markings are evident. A long shot perhaps, but any ideas how I can ID it? The manufacturers of ti valves that I can think of: Del West, Ferrea, Manley?
The valve is 49 mm, 11/32” stem.
Thanks for any help!
Old 02-07-2022, 08:23 PM
Any chance that they're cut down chevy valves? The lock/keeper groove appears to be old (pre LS) chevy style, and 11/32" stem is standard sbc size. The chamber side is not a standard Del-West valve. The tip appears to be pressed in hardened steel (should be, Ti is too soft), check with a magnet. If they're cut down chevy valves, the "factory" markings normally near the top of the valve have been cut off.
Old 02-08-2022, 04:44 AM
It's a 914 ...
Thanks dannobe. The tips are magnetic (the rest of the valve isn’t of course), suggesting they weren’t shortened. Length is 4.335” for whatever that’s worth.
Old 02-08-2022, 05:18 AM
Lots of people remove the steel tip and reinstall it after cutting down the stem and drilling the end for the removed steel tip. It's not uncommon. The fact that it still has a chevy valve lock groove and chevy sized stem (11/32") leads me to believe they've been cut.
This would also remove the manufacturer's info, which is nearly always up near the top of the valve, making ID'ing the valve difficult.
Small block chevy valves are 4.9" or so long. Plenty of room to cut down to fit other applications.
Del-West valves are usually laser etched with their logo on the chamber side, where the recess is in yours.
Old 02-08-2022, 07:00 AM
It's a 914 ...
Thanks, that's helpful to know how to proceed. My best bet is probably to call the the manufacturers I mentioned in my first post and see which can spec a replacement as close as possible to the one I'm replacing.
Old 02-08-2022, 12:30 PM
Ti valves
Del West were always flat on the top.A lot of these companies are not around anymore.Fred
Old 02-08-2022, 02:50 PM
Racer
winders's Avatar
You could check with Bill at Xtreme....he might know.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 02-08-2022, 03:11 PM
Ollies930's Avatar
You could also try Victory 1. They will custom build to whatever spec you give them.
Old 02-09-2022, 12:47 PM
