320-350 hp 3.0 SC
Beloved Porsche Owners,
It's time to rebuild my 1979 3.0 CIS engine. I have it in my heart I want to rebuild it myself to mirror the 320-350hp, N/A engine as advertised by GProgramm of NY. A few details I know (without GProgramm divulging their combination to me) is it consists of: -3.4 litre -46 mm carb -964 cams -Double plug xdi ignition Questions: What would be their piston/cylinder size? I'm assuming it would need 100+mm and a drivable compression that runs on 93 octane. And from a 3.0, can you achieve 3.4 displacement w/o a bigger & likely 3.2 crank (which is impossible to find?) |
It's a 914 ...
A common 3.4L combo is 74.4 mm stroke by 98mm pistons. That's a different stroke crank than your SC has. I think 98mm cylinders may be slip fit for your engine. Perhaps someone here more knowledgeable can confirm.
You could use larger cylinders like 102 mm with your 70.4 crank. That's a less common combination, but it could be made to work with custom pistons. 964 cams would be a little mild for a large carbed engine. You could call one of the cam grinders like Dougherty, Web, or Elgin and discuss your build to get a recommendation. |
Racer
I wouldn't call the cam grinders. I would get someone that knows what they are doing to architect the engine for you and rely on their expertise for piston, cylinder, crank, rod, and cam, etc., choices....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
That description the OP doesn't sound anything like 300HP to me?
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
(man/dude)
I would re-aim my sights on a 3.2SS (your motor with 98mm pistons and already pointed out) plenty of info on here about a build such as that.
A lofty Hp goal like that might not be the best street motor. I'd second the recommendation to call or email a cam grinder, specifically John Dougherty at Dougherty Racing Cams.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
3.2SS is what I have built. Not yet broken in, but should push out some decent power.
Mine is based on a '79SC. |
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
https://www.gprogramm.com/ |
I got the feeling right away this was a promotional post, I fell for it and looked them up.
Where is the o/p? Phil |
(man/dude)
Matt Farrah did a video on one of their builds. Nice enough car, but I call BS on 350Hp from 3.4L with 964 cams and a 6500RPM redline...... but whaddya want for $200K?
Correct, and Matt Farrah? Ok, not someone on my list of people to trust about things automotive... lol
(man/dude)
I hear you there....but occasionally he drives an interesting air-cooled car and I remember this one. It's actually a nice build based on a 79SC, and a refreshing change from the Singer-wannabee crap you see so much of.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 02-24-2022 at 05:56 AM.. |
(man/dude)
How about "bespoke"? If I hear that word one more time I'm going to barf.
Patina, never heard of it till Wayne Carini abused it on his show. To me it now means an excuse for crap.
Don't get me wrong, I'm not looking for perfection, but cracked paint is crap. |
(man/dude)
How about drilled door handles and louvered decklids and molded in "r" taillights?
I guess it's my turn.... WTF is a Wayne Carini? OK EDIT - I googled it. Cable TV crap. Not for me.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 02-24-2022 at 03:35 PM.. |
Yup. The only thing worse than Magnus's cars is his driving...
1971 911T Irish Green Coupe |
Jonny we all know you live for the visceral feel of bespoke patina!
