Jeff Alton's Avatar
We, wipe clean of oil grease, solvent tank, jet wash, then (depending on part) glass bead blast/ultrasonic/hand clean.
Cheers
www.turn3autosport.com
Old 03-23-2022, 07:22 PM
Under the radar
Trackrash's Avatar
Cheers
What solvent are you using?
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-26-2022, 12:46 PM
Jeff Alton's Avatar
Most recently Wurth Eco Part Wash solvent. Nothing is submerged, it is used in the parts wash tank with a running stream out of the nozzle and brushes.
Old 03-28-2022, 01:40 PM
Drive it like u stole it.
jonesb930's Avatar
I finally broke down and bought a small parts washer. I don't really have the room for a full size unit so I picked up a Jegs 5 gallon (holds 3.5g of solvent) unit. I added a parts washer brush on a hose as well as an additional splash guard using some rubber and aluminum to keep it from splashing out the back through the hinge (biggest complaint I saw online). I am very happy with it! All in I think I am around $130 for the washer including the few upgrades mentioned.
For solvent I am using PSC-1000 from Tractor supply for $44.99 per 5gal can.
https://www.tractorsupply.com/tsc/product/crown-psc-1000-parts-cleaner-5-gal
Below is my first part through the washer. The PSC-1000 has a very slight smell, nothing like mineral sprits.
First pic is part way through cleaning.
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 05-15-2022, 01:42 PM
I am about to clean my 75 911s engine, and I would like to try diesel fuel.
Old 05-15-2022, 02:41 PM
