Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Copper Base Gaskets 97mm ID
With 1.0mm base gaskets, deck height is only 0.8mm. I fear insufficient piston to head clearance … yet to torque the head with modelling clay ..
Anyone know of 1.2 or 1.25mm thickness copper base gaskets?? Or where to source them. I could have some made but maybe they’re available off the shelf somewhere ..??
Old 01-27-2022, 06:51 PM
Try not, Do or Do not
Henry Schmidt's Avatar
We definitely stock 1.00mm and a we made some custom 1.5mm.
I will have to check stock.
No chance on the 1.25
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-27-2022, 07:06 PM
Rosco_NZ
Thanks Henry! 1.5mm could be the ticket if you have some on a shelf ..
Old 01-28-2022, 02:02 AM
Rosco_NZ
Rounding out this one, we stacked 1.0 & 0.2mm base gaskets to give us 1-1.2mm PtoH clearance. Note the use of JE pistons has a different profile at the margin of the piston crown meaning the heads do not need to be chamfered. This is a thing if you’re using Mahle 90mm I think.
Old 02-19-2022, 02:50 PM
Just for anyone who is looking for custom base gaskets, LN engineering seems to have quite a selection, and can custom make most any size you need.
Old 03-04-2022, 04:47 AM
