-   -   IDA Weber carbs (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1118081-ida-weber-carbs.html)
hipdoc 05-02-2022 10:51 AM
IDA Weber carbs
Does anyone know where to have work done on a 911 IDA Weber carb. My air-mixture screw broke inside and need to have it repaired.
Hipdoc
Trackrash 05-02-2022 07:34 PM
Picture? I found that p a r t s k l a s s i k .com has Weber parts. BTW, I don't see Pelican having them.
Zuffenwerker 05-02-2022 08:11 PM
A machine shop might not be a bad idea. There are lots of porsche specific machine shops in CA that would be real familiar.
Daniel
hipdoc 05-02-2022 09:46 PM
What’s the name of the machine shop(s) in CA that could tap it out?
Trackrash 05-02-2022 09:51 PM
Post a picture. I bet one of the experts here will have a solution. But we need to see exactly what you are dealing with.
Cairo94507 05-03-2022 07:09 AM
You might try Aase Motors (704) 770-8187 - 1104 E. Elm Avenue, Fullerton, CA 92831. Alan is their motor man and is terrific. Good luck. :)
Mark Henry 05-03-2022 07:20 AM
Jerry's Broken Drill & Tap in Santa Ana. EDM, they can burn it out without damaging the surrounding metal.
https://brokentap.com/
https://www.youtube.com/watch?v=8VvLJWkFGIw
Henry Schmidt 05-03-2022 08:12 AM
Generally we only do complete restorations on MFI throttle bodies, Solex and Weber carburetors. We can fix almost anything.
The question is: do you want them restored?
http://forums.pelicanparts.com/uploa...1651590445.JPG
http://forums.pelicanparts.com/uploa...1651590445.jpg
