Hbrand
hbrand's Avatar
Cam timing on custom engine
I have a 1982 Porsche 911, Euro 3.0, 9.8:1 compression, big intake and correct fuel distributor and distributor, 964 cams.
I had all the heads rebuild and would like to set the cam timing to decent torque and still good RPM.
Using stock exhaust with cat bypass.
What would be a good cam timing considering my engine specs?
Thank you for helping, Harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 05-10-2022, 03:37 PM
Hi. With the exact same spec’s as yours included SSI’s I used 1,35 overlap on my previous build. The engine made very good torque all over the powerband and revved very good. HP at the cranck was 250 and torque 298Nm / 220 ft lbf.
It would help your engines performance quite a bit using SSI’s instead of original exhaust.
Old 05-10-2022, 10:39 PM
AndrewCologne's Avatar
@ Classic 911
A 3.0 ROW with 9.8:1 CR ... all stock ... and here just SSIs and 964 cams will bump up the power of about approx 50 HP?
@hbrand
964 cams will be set on intake to 1.25 at overlap per default, ... but you can advance a bit more like Classic 911 did. To achieve even more torque you can advance even a bit more, .... but all advancing approaches beyond the factory specs makes it necessary to check the valve piston clearence over all 720° of the crank.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 05-11-2022, 06:50 AM
Hbrand
hbrand's Avatar
Cam Timing
Thank you for your help
Harold
Cheers
1969 Mercedes 280SL
Old 05-11-2022, 07:13 AM
Originally Posted by AndrewCologne View Post
@ Classic 911
@hbrand
Sorry, forgot to tell that my build had 46MM PMO ITB’s
Old 05-11-2022, 11:18 AM
targa72e's Avatar
My experience dyno testing cam timing (3.0 big port stock intake, cams and headers) showed that best power was with most advanced timing you could run and still have appropriate valve clearance. The trade off was a few HP over 6Krpm for more Torque (thus power) everywhere else.
john
Old 05-11-2022, 01:21 PM
john
This has been my experience too.
I normally run the 964 cam set at 1.5mm min. You really need to check your valve-to-piston clearance and from memory, the intake valve approx 12-15 deg ATDC is the critical point.
Next question is "how much clearance is enough"?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 05-11-2022, 03:32 PM
Mahle says 2mm intake 2.5mm exhaust is minimum clearance. I remember reading in the early WSM though and Porsche said 1mm minimum. Interesting how most specs like this have changed overtime.
Daniel
it's not leaking....it's just marking it's territory
Old 05-11-2022, 07:34 PM
With much timing advanced 964 cams on 3.0 Engines I would suggest using pistons with valve pockets (like the 10.5:1 from JP or Woessner) to have more clearence to play with, but with these higher premium fuel octane is mandatory.
Old 05-12-2022, 03:50 AM
Hbrand
hbrand's Avatar
I did set the overlap to about 1.5mm
Engine started on the first try. Now running in. Then checking valve play
Thank you for your tips.
Greetings, Harold
Cheers
1969 Mercedes 280SL
Old 05-19-2022, 04:08 PM
