Under the radar
Trackrash's Avatar
Wonky cylinders
We got our cylinders back from EBS. 2,7 bored to 92mm. Bores look good.
However when I measured the cylinder heights some of the cylinders were not perfectly square.
One cylinder in particular measured 3.354" on one side and 3.360" on the other.
So the question is will this work, or do I need to send them out? Or clean them up on a glass plate with 400 grit?
Two other cylinders were also not square, but not as bad as that one.
What say the brain trust?
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-11-2022, 08:11 PM
I don't know the answer but I do know what questions you need to answer before others can answer.
A. Will the angle tilt the cylinder relative to the case, or just the cylinder head relative to the cylinder? In other words, which end(s) are/is not orthogonal to the barrel?
and
B. Which direction does the angle go? Parallel to the crank, or orthogonal to it? Orthogonal will simply rotate the piston on its pin, while parallel will attempt to bend the piston, pin and con rod system.
Sent from my SM-G988B using Tapatalk
Old 05-11-2022, 08:38 PM
Did you measure them before they went out?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 05-12-2022, 02:48 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
They need to be square and equal too. If not, proper sealing will be unlikely and in addition, the cam box might be distorted affecting the ability of the cam to turn without difficulty.
1986 Targa Guards Red
2021 MT09 SP
Old 05-12-2022, 05:10 AM
It's a 914 ...
stownsen914's Avatar
.006" sounds like a lot. Something isn't going to seal properly, either at the cylinder head interface (bad), or at the base of the cylinder where it meets the case (not quite as bad possibly, but still bad). Not sure truing them up on a glass surface is going to bring this kind of unevenness back into spec.
Old 05-12-2022, 05:18 AM
Try not, Do or Do not
Henry Schmidt's Avatar
A machinist with a good lathe can square them up. Base gaskets to achieve the proper deck are readily available.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-12-2022, 06:29 AM
Under the radar
Trackrash's Avatar
Yeah, I know a machinest. LOL.
I didn't bother to measure them before sending them out, since there was not real leakage at the base, the head seals were pristine, and the bores looked good. Live and learn I guess. But I also assumed that EBS would checked them.
Oh well. We will get it done right.
Gordon
Old 05-12-2022, 10:50 AM
Nice catch. I like the idea of using a mike there. I use a height gauge and have noticed some uneven measurements before but not as much as .006”. Wonder if that cylinder has always been that way.
Will the machinist just cut on the bottom ? or top of the cylinder…ce ring groove.. or both ? Just curious where the .006 deviation is top or bottom.
Daniel
it's not leaking....it's just marking it's territory
Old 05-12-2022, 06:29 PM
