Diving in 911
964 P and C help needed
Trying to sort some pistons and cylinders. Bought used off a low mile car, very nice, specked out flawless. He’d to tops head blasted and lost the numbers and E. Only marking on the piston are 100p36 on the inside. Trying to figure out if there is a way to determine orientation. Is the E on the same orientation as the numbers on the inside? Is there a way to also ensure these are 964 and not 993? Pistons (Which would be odd as they came from a Singer donor car). Because, as I understand it, the pistons won’t work with my 964 rods? Thanks to anyone who can shed some light
Diving in 911
Pics
1976 911s Special Edition Turbo bodied IROC tribute 2002 911 Carrera C4S 1971 914 1.7 Tangerine 1989 964 Coupe/1992 964 Cab 1987 928s4 Granite Green / 1986 951 |
Diving in 911
Inside the pistons it has “100P36+“
The cylinders are definitely 964 , pistons as well. It looks like someone machined the crown for a little more clearance under the "2" in the pic. I have a set of those pistons in my shop, I measured them and the crown and valve clearance is symmetrical. I would orient the machined portion up ( intake side ) , seems to make sense. Or they machined a little material off the the top of the piston to lower compression.....maybe.
'77 1973 911RS Backdate, 2.7 liter w/webers '70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress '75 911 RSR street car in progress '77 930 Replica '75 993 GT2 EVO race car , 3.6 TT '79 928 5 speed money pit in progress |
Those are Mahle pistons.
There is a mark to the flywheel side for orientation much like the turbo pistons have a squiggle line with a point Bruce |
Diving in 911
Mark
No marks on the crown of these. The soda might have got them. If the Clearanced side is oriented to the big valve the rest should fall in place, correct?
964 pistons w/100P36.
The squared corner by the pin hole goes to the left on installation.
Diving in 911
Thanks John/ Bruce/Pocv0!
