JoeMag's Avatar
Where is molybdenum in our engines?
I do oil analysis relatively frequently on my motor... In a recent anlysis moly went up to 13ppm from the typical 0-3ppm. Any idea where it might come from?
A few years ago I had a bump in titanium from very low levels (0-2ppm) to around 25ppm. Only place I knew that my motor had Ti was on valve retainers and could not figure out why they would be "wearing". Turns out I had a broken inner valve spring and it must have been scraping retainer.
...So, I like to check these things out. basic run down of motor.
964 crank
carillo rods
mahle 3.8 p/c
993 heads
factory and Intervalve valves
ebs race springs w ti retainers
solid factory rockers in 993 cam towers
daugherty cam
running brad-penn 20/50
Old 06-01-2022, 09:50 AM
Ingenieur
Chrome molybdenum is a common steel valve spring retainer material. Did you change out those Ti retainers for steel by any chance?
Old 06-01-2022, 02:39 PM
JoeMag's Avatar
Thanks the the thought however got new Ti retainers with the new EBS springs.
Old 06-02-2022, 04:38 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
And there we have the value of having an oil analysis done.
1986 Targa Guards Red
2021 MT09 SP
Old 06-02-2022, 12:28 PM
Racer
winders's Avatar
http://wearcheck.com/virtual_directories/Literature/Techdoc/WZA047.pdf
MOLYBDENUM (Mo) sources:
Piston rings, synchro rings, oil additives, greases, solid additives (anti-friction), internal coolant leak.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 06-02-2022, 01:00 PM
