-   -   '72/'73 2.4L/2.7L GE Head Gasket (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1122088-72-73-2-4l-2-7l-ge-head-gasket.html)
Cbpowell 07-03-2022 03:12 AM
What is correct side to face cylinder head?
The GE head gasket on a 1973 2.4/2.7 that seal the cylinder to the head is not symmetrical.
One side of gasket seem longer and sharper, and hides the spring inside the gasket.
The other side seems a bit rounder and there is a bit of exposed spring. The gasket sits proud of groove in cylinder with spring in and fit inside with spring out.
Thank you.
Flat6pac 07-03-2022 08:11 AM
You most assuredly want the edge that sets proud so there is some crush taking place
Bruce
Cbpowell 07-03-2022 10:54 AM
It actually sits proud regardless of side. Is there a definitive side that faces the head?
gled49 07-03-2022 12:37 PM
Long edge to the cylinder, but it really doesn’t matter
Cbpowell 07-03-2022 12:48 PM
Long edge to cylinder feels better than other way around.
john walker's workshop 07-03-2022 08:21 PM
Agreed.
