| Registered Join Date: Oct 2020
				'72/'73 2.4L/2.7L GE Head Gasket
			What is correct side to face cylinder head? The GE head gasket on a 1973 2.4/2.7 that seal the cylinder to the head is not symmetrical. One side of gasket seem longer and sharper, and hides the spring inside the gasket. The other side seems a bit rounder and there is a bit of exposed spring. The gasket sits proud of groove in cylinder with spring in and fit inside with spring out. Thank you. | ||
|  07-03-2022, 03:12 AM |
| Registered Join Date: Oct 2008 Location: Nash County, NC.
			You most assuredly want the edge that sets proud so there is some crush taking place Bruce Last edited by Flat6pac; 07-03-2022 at 04:48 PM.. | ||
|  07-03-2022, 08:11 AM |
			It actually sits proud regardless of side. Is there a definitive side that faces the head?
|  07-03-2022, 10:54 AM |
| Registered Join Date: Feb 2009
			Long edge to the cylinder, but it really doesn’t matter
|  07-03-2022, 12:37 PM |
			Long edge to cylinder feels better than other way around.
|  07-03-2022, 12:48 PM |
| Registered Join Date: Mar 2001 Location: Marysville Wa.
			Agreed.
				__________________ https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 | ||
|  07-03-2022, 08:21 PM |
