Aluminum 901/05 Engine Case Tumble-Polished: Perfection Defined
I'm going to keep it to a few words and let the photos speak.
Ollies Automotive Machining has tumble-polished this aluminum engine case in ceramic media. Following this step, the oil gallery plugs were removed and the oil galleries cleaned to ensure that no media remains in the case. The media tumble was $100, hot tank was $30 and the R&R of the oil plugs was $60.00. I had a few other things done while it was there, like the case squirters you see below. EDIT: Since this was posted Ollies moved to Lake Havasu, http://www.olliesmachine.com/ Enjoy!
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) Last edited by 304065; 10-09-2011 at 10:44 AM.. |
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Wow John that is pretty!!
Seems to be reasonable pricing too....
John |
Mama !
What have you decided to build John ?
Du must schwein haben '67 901/05 rebuilt 2.2 Bultaco Metralla 62 "XDina" '68 BMW R69S |
Very nice John. Engine porn for sure. Maybe just soft porn, at this stage, but engine porn, none the less.
Jon |
Gentlemen,
Coming from you fellows, (a '66 owner, a '67 owner and a '66 owner!) that's high praise. Thanks-- I think they did a very nice job. The build plan is final: The engine will be a completely stock appearing 1966 901/05, but will be 81x66, 9,3:1 compression with an improved version of Solex cams, SC oil pump, ARP bolts, and every internal update the factory offered, such as squirters and the oil bypass modification. Carburetors will be the stock Weber 40IDA. I'm hoping for better than 140 HP with SSI '67-style heat exchangers and a quiet muffler.
Can't wait to see the progress.
I just put SSI's on my car and the difference is amazing.
Senior??? Oh very well
What is a case squirter?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
The case looks fantastic. Far better than what I managed with my steam cleaning and elbow grease.
When they did this did they have to protect the case mating surfaces from the ceramic media? Kirk
1989 911 Carrera 4 (964) |
Hey John how did the align-bore check out was it still spec?
Tony Proasi 1969S 1957 VW Pickup |
John;
Aren't you being a little conservative with the #'s ? You could get 140hp with a 901/05 by just removing the restrictors on the heat exchangers. You should do better than that with 9.3 compression and hotter cams , no ?
Less brakes, more gas!
John,
What was shipping from NYC? I have waffled between sending mine and just putting the elbows on it... Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Align-bore was checked and found within specifications.
Yes, I am being very conservative. I had SSIs before which didn't have any restrictor rings, so no changes there. The combination of higher compression and the improved cams should provide an improvement, but I'm not expecting TOO much insofar as I'm still using 39/35 valves with 32mm ports. Remember, the 901/30 rally engine used 39/35 valves, 32mm ports, "S" pistons and cams and 46 Webers and delivered 150HP. We still don't know what the torque curve looked like as it, and the torque peak value were never published as far as I can tell. Michael, shipping via DHL (the carrier of choice for all things Porsche, and I'll admit that the RS Spyder's sponsor has a lot to do with it) was about $55 from New York City. Shipping back was $90, for a 70 pound box with copious amounts of cardboard to protect it.
John;
Are you going to go with 32mm venturis ? 130 main jets ?
I love seeing a sandcast 2.0 on a granite countertop. John I think your engine will be worth more than 140hp. Mine has a bit more than what you are planning such as a port and polish and a crank fire ignition, a bit more compression and my displacement was taken out to 2200cc's and I think the engine has 180hp. You should be at no less than 160 with your setup. Regardless of that, you have a beautiful case to work with. That is how mine was done too.
John have you ever thought about blasting the housing with dryice ?
bob http://corvair.webdrache.ch/sccmcms/restore/karosserie/140.php
99" 996 C2, 04" Mini Cooper, 66" sprite (scca "DP" sold) 87" M5 (sold), 73" 914 2.2 (sold), 72" 914 1.7 (sold) 79" Alpina B6 (sold) |
WOW!!! is there an english version of this???? Is that a totally cool way to clean away yrs/miles of crud or what!!!!!!!!!!!!!!!!!
Is this available in the US?? Is this the dry ice thing? Bob
I live for 911 tweaks... |
