Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
304065's Avatar
Aluminum 901/05 Engine Case Tumble-Polished: Perfection Defined
I'm going to keep it to a few words and let the photos speak.
Ollies Automotive Machining has tumble-polished this aluminum engine case in ceramic media. Following this step, the oil gallery plugs were removed and the oil galleries cleaned to ensure that no media remains in the case. The media tumble was $100, hot tank was $30 and the R&R of the oil plugs was $60.00. I had a few other things done while it was there, like the case squirters you see below.
EDIT: Since this was posted Ollies moved to Lake Havasu, http://www.olliesmachine.com/
Enjoy!
'66 911 #304065
'71 911E PCA H-Stock Club Racer #806
Ex-'88 Carrera (Sold 3/29/02)
Old 06-08-2007, 04:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
304065's Avatar
'66 911 #304065
Old 06-08-2007, 04:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
jhora's Avatar
Wow John that is pretty!!
Seems to be reasonable pricing too....
John
Old 06-08-2007, 04:35 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
JCF JCF is offline
Mama !
What have you decided to build John ?
Du must schwein haben
'67 901/05 rebuilt 2.2
Bultaco Metralla 62 "exDina"
'68 BMW R69S
Old 06-08-2007, 05:13 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
shbop's Avatar
Very nice John. Engine porn for sure. Maybe just soft porn, at this stage, but engine porn, none the less.
Jon
911 #303129
81' SC project
70 SS 454 El Camino
Old 06-08-2007, 06:32 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
304065's Avatar
Gentlemen,
Coming from you fellows, (a '66 owner, a '67 owner and a '66 owner!) that's high praise. Thanks-- I think they did a very nice job.
The build plan is final: The engine will be a completely stock appearing 1966 901/05, but will be 81x66, 9,3:1 compression with an improved version of Solex cams, SC oil pump, ARP bolts, and every internal update the factory offered, such as squirters and the oil bypass modification. Carburetors will be the stock Weber 40IDA.
I'm hoping for better than 140 HP with SSI '67-style heat exchangers and a quiet muffler.
'66 911 #304065
Old 06-09-2007, 09:04 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Senior Member
I dunno John, something tells me that you're going to end up putting your engine components, like the heads and case, in a glass case in your living room.
1996 C2
Old 06-09-2007, 11:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
JCF JCF is offline
Can't wait to see the progress.
I just put SSI's on my car and the difference is amazing.
'68 BMW R69S
Old 06-09-2007, 01:25 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Senior??? Oh very well
fly4val's Avatar
What is a case squirter?
Old 06-09-2007, 04:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
126coupe's Avatar
squirts oil under the piston for improved cooling
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 06-10-2007, 06:49 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
kirkf's Avatar
The case looks fantastic. Far better than what I managed with my steam cleaning and elbow grease.
When they did this did they have to protect the case mating surfaces from the ceramic media?
Kirk
1989 911 Carrera 4 (964)
Old 06-10-2007, 09:17 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
911quest's Avatar
Hey John how did the align-bore check out was it still spec?
Tony Proasi
1969S
1957 VW Pickup
Old 06-10-2007, 05:54 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
JCF JCF is offline
John;
Aren't you being a little conservative with the #'s ?
You could get 140hp with a 901/05 by just removing the restrictors on the heat exchangers.
You should do better than that with 9.3 compression and hotter cams , no ?
'68 BMW R69S
Old 06-10-2007, 05:58 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Less brakes, more gas!
euro911sc's Avatar
John,
What was shipping from NYC? I have waffled between sending mine and just putting the elbows on it...
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'03 330i Family hauler w/ extras
Old 06-10-2007, 06:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
304065's Avatar
Align-bore was checked and found within specifications.
Yes, I am being very conservative. I had SSIs before which didn't have any restrictor rings, so no changes there. The combination of higher compression and the improved cams should provide an improvement, but I'm not expecting TOO much insofar as I'm still using 39/35 valves with 32mm ports. Remember, the 901/30 rally engine used 39/35 valves, 32mm ports, "S" pistons and cams and 46 Webers and delivered 150HP. We still don't know what the torque curve looked like as it, and the torque peak value were never published as far as I can tell.
Michael, shipping via DHL (the carrier of choice for all things Porsche, and I'll admit that the RS Spyder's sponsor has a lot to do with it) was about $55 from New York City. Shipping back was $90, for a 70 pound box with copious amounts of cardboard to protect it.
'66 911 #304065
Old 06-11-2007, 06:00 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
JCF JCF is offline
John;
Are you going to go with 32mm venturis ?
130 main jets ?
'68 BMW R69S
Old 06-11-2007, 06:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
I love seeing a sandcast 2.0 on a granite countertop. John I think your engine will be worth more than 140hp. Mine has a bit more than what you are planning such as a port and polish and a crank fire ignition, a bit more compression and my displacement was taken out to 2200cc's and I think the engine has 180hp. You should be at no less than 160 with your setup. Regardless of that, you have a beautiful case to work with. That is how mine was done too.
Old 07-03-2007, 05:19 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
HKZ Bob's Avatar
John have you ever thought about blasting the housing with dryice ?
bob
http://corvair.webdrache.ch/sccmcms/restore/karosserie/140.php
Old 07-22-2007, 07:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
alpina's Avatar
Send a message via AIM to alpina Send a message via Yahoo to alpina
bob
How and where can you get that done
66" sprite (scca "DP")
73" 914 2.2 (sold)
72" 914 1.7 (sold)
79" Alpina B6 (sold)
Old 07-27-2007, 08:31 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
HKZ Bob's Avatar
try this link
Old 07-28-2007, 11:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Tags
901/05
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
