Forced Induction Junkie
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Super Moderator
The engine is mostly back together. Will have it back running this weekend mostly likely. I'll give an update then.
I'm in the process of planning oil tank baffles, just need a few more hours of MIG welding practice. LOVE my new MIG welder!
Author of "101 Projects"
Okay, I've read this entire thread. I can't quite figure out what the problem is? Pulsing at idle you said? Fuel smell? Pretty vauge. Also, the engine probably isn't run in yet - takes about 1000 miles. I would have waited for 1000 miles before I tore anything down again...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Super Moderator
Wayne, there were two other threads behind it that described the problem, but essentially it boils down to the fact that I was getting SO much blowby, and hence crankcase/oil tank pressurization that it was literally emptying my oil tank into the overflow tank (required for racing)
Super Moderator
The motor is back together and I'm getting very similar air as before comign out of the case. It think now maybe the rings just haven't seated completely.
Just gonna deal with adding oil and draning the overflow tank for a few thousand miles. If it doesn't go away then, I'll look into this again. Only problem is that I am getting so much oil out, that the overflow tank, well, overflows and spews oil out the breather. I added more slope to the oil-tank/breather connecting hose and made a small orifice to help keep the amount of oil getting into the overflow tank down.
Banned
During the initial engine break in its very important to do several FULL throttle accelerations and deaccelerations to seat the rings. If if this is not done it could take many thousands of miles, if ever to break in the rings. You can check eany auto tech book on this subjest to verify this fact.
If you have gone to far beyond the initial condition it may be almost impossible to get the rings totally broken in. The only way I know of is to do the honing operation I mentioned earlier to change this condition. If the cylinders are the type that cannot be honed you may be in trouble, but I am pretty sure I read that you have the kind that can be. Try it for a couple of races or thousand miles as is. If you do not have better luck then, try this honing step, it really does work like magic. It puts just engough of the type of cross hatch pattern in the cylinder of the correct type to seat the rings real good. |
Super Moderator
Snowman, I understand. Thing is -- I did this. I went through a series of full throttle accelleration and deccleration (in gear for reverse pressure as well).
1. I did a 20 minute cam break in at 2000 RPM. 2. I then took the car out on the road, and went full throttle to 4000, then back down to 2000, then up to 4500 and back down. Then let the engine settle for a few minutes by just driving while varying RPM. Then up to 5000 and back to 2000 RPM, etc.. etc... HARD acceleration all across the rev range and back down. Had 50-75 good variable accleration miles on it, then off to the race track. First session was a mild practice session.
Banned
There is still bad luck. It could be that the rings just do not want to seat for some reason, unknown. Go for it for a while, couple of races or 2000 miles. If then you still feel there is a problem try the hone thing.
Chris,
I guess you've tried everything else and the rings indeed may not have seated, thus the excess blowby. However, instead of reducing the orifice passage from the tank to the catch tank, I'd increase the ID as much as possible. A larger ID (3/4" min.) lets the crankcase breathe easier, reduces air velocity and allows better separation of oil and blowby. How about using a straight 30 wt. oil during this break in period rather than any fancy multi-vis oil? Leave out the oil additives and verify the oil level is a quart (maybe two) or so below the "full" mark on the dipstick. Sherwood |
Super Moderator
Hmmm... Both good ideas! THanks.
Sherwood, can you recommend a brand?
is that brass restrictor sleeve in the breather hose from the tank? it helps to keep oil from passing, but allows vapors to escape.
Super Moderator
JW, There was no restrictor from the tank to the breather before....
On a suggestion I have added one. THe hose is about 3/4" ID. I made one by inserting a coupler with a washer welded to it. Essentially reducing the diameter at that point to 1/4". The coupler is positioned halfway up the arc made by the hose between the tank and breather neck to allow the oil to run back into the tank.
"can you recommend a brand?"
Others might recommend continuing with 30 wt. non-detergent oil. I say just use some HD 30 wt. Castrol or equivalent, but that's just my opinion. I would place oil separator devices in the tank area (either oil tank or catch tank) where the vapors have room to move rather than placing a restriction in the breather hose. Sherwood |
i'm talking about the factory tube type restrictor with curly brass wool packing that was in the breather hose/filler neck originally.
Super Moderator
Huh... I've never seen that one... Do you think one could be fabricated?
Okay, I've thought about this some more. Here is what I recommend:
- Run compression check again - Run leakdown check - Run a CO/HC check If all three come back normal, then you're fine - your rings have seated, and your engine is running well. The CO/HC check will be the final indicator - if the HC are low, then you're getting good combustion. I'm going to go out on a limb here, but I think the problem may be with your oil tank setup. I have no idea what you're using, but I think you may have it plumbed incorrectly. If all three of the above tests check out okay, then I would look very closely at your oil tank system. -Wayne
the hose from the engine breather does go to the side of the tank, and the hose from the filler neck to the catch can, right?
Super Moderator
JW. Yes that is correct.
Wayne, The pickup is in the rear, return to the front leading to oil filter. The crankcase vent hose goes to the side of the tank near the top and above the internal oil sperator, then the tank vent from the side of the filler neck goes to the catch tank. The blowby, in and of itself was not necessarily concerning me too much, it was the fact that I was getting huge amounts of oil into the catch tank, so much so, that my oil levels were getting dangerously low during long track sessions... If I could fix that, blowby be damned. The CO/HC test is a good idea though! I'll have to check that after a few hundred miles...
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 06-09-2003 at 01:19 PM.. |
your restrictor, with the 1/4" hole may not be full flow, that is pressure may be forming behind it, causing any oil in the vicinity to be forcefully blown thru the hole. the OE unit is full flow, but holds oil droplets back. one down at the filler neck, and another at the top of the arc might help.
Super Moderator
JW. Good point. I just added the restrictor, haven't run the car with it, so it wasn't causing the problem. Makes me think I should remove it and put in something similar to the factory one then.
